Old 04-30-2016, 02:27 PM   #1
Mrturner1
Help identify this noise (cont') better video
I got a better video, I'm hoping you can hear it a little better now. It's a squeak/ticking that isn't consistent, and it's happening during idle and while I rev it up a bit. Lemme know what you think guys.
(Hoses and vac lines are hokey pokey right now pls ignore lol)
https://youtu.be/u-CHqu7Q9q8
Mrturner1 is offline   Reply With Quote
Old 04-30-2016, 02:31 PM   #2
Mrturner1
Re: Help identify this noise (cont') better video
Also check this one out, it's in the passenger fenderwell
https://youtu.be/KcJcnga1rW4
Old 05-01-2016, 04:44 PM   #3
Mrturner1
No ideas? This is driving me crazy
Old 05-01-2016, 11:03 PM   #4
trac209
Sounds like the ring gear is touching the starter armature bushing a bit
trac209 is offline   Reply With Quote
Old 05-05-2016, 04:27 AM   #5
Guy67UK
Guy67UK's Avatar
As above or loose converter bolts/cracked flexplate
Guy67UK is offline   Reply With Quote
Old 05-05-2016, 07:29 AM   #6
Toms67
Toms67's Avatar
This is reaching out there. Had a broken fuel pump spring one time. I can't tell from the noise you have. It was many moons ago.
Toms67 is offline   Reply With Quote
Old 05-05-2016, 10:35 AM   #7
Mrturner1
Nailed it. Crawled under the truck and the starter was wiggling. The problem is only one bolt holding it to the block is tightening up. The other one just spins when I tighten it so there's only one holding the starter
