Water pump replacement...what else?
I'm going to replace my water pump...it started sqeaking and I see a drizzle from the weep hole. Anything else I should consider checking and or replacing since I will have it apart? Lower radiator hose..yes. ...Upper is new....Radiator is new. Pulleys all new. Thermal fan clutch is new. Thermostat is new..180 deg. Heater hoses are new. Harmonic balancer is new.
It's original 307 and I don't know the mileage or how well it was maintained before I got it. Runs great, no smoke. Mild cam with roller tip rockers, fresh rebuilt stock heads.
1970 C10 Short Stepper with 71/72 front clip. Last edited by BugzC10; 04-30-2016 at 06:27 PM. |
Re: Water pump replacement...what else?
Belts!
yes...Forgot to mention...belts are all new.
1970 C10 Short Stepper with 71/72 front clip. |
If you dig a little deeper you can do the timing chain!
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
I did think of timing chain, but didn't want to say it out loud.
![]() Can I get away with lowering the oil pan enough to r&r the timing chain cover without replacing a fairly new one piece oil pan gasket?
![]() Join Date: Feb 2016
Don't automatically condemn the timing chain.
Remove your distributor cap and using a socket on the harmonic balancer, turn the engine forward and back to see how much rotation your can turn the crank before the distributor rotor will move. That gives you an idea of how much slack is in the timing chain and gears. |
Thanks for the tip...great idea!
When you pull off your old pump you can look in the water jacket openings to see how much crud build up there is and decide if you need to flush your system. I have heard good and bad about using vinegar to flush with. If you think you might need to flush the system you may want to do it before you take the old pump off that way you are not circulating crap through the new pump.
Thanks for the suggestion...I did a flush before I replaced my radiator last year.
