04-30-2016, 04:38 PM | #1 |
First start! can i get 2000rpm with the idle screw?
Im firing my engine with new cam this weekend. Its on the frame but I have no cab, so no gas pedal.
I dont want to try to hold the throttle on the carb with my hand for 20 minutes while breaking it in. I dont have a real tach hooked up but I was planning on using the tach in my timing gun. If I screw the idle scew can I get it to 2000rpm? Anybody have ideas or advice? Also whats more important tuning or breakin. for example say the engine is not running all that great, should I ignore that and just breakin the cam for 20 minutes and then fiddle with it, or try to somewhat set the timing and then run it at 2000rom for 20 minutes? |
04-30-2016, 05:21 PM | #2 |
Re: First start! can i get 2000rpm with the idle screw?
You should be able to set the high idle from the choke high enough without having the choke on, and yes, keep it running, as long as its running you can fiddle with the timing, (distributer) to get it close. but keep the RPMs up for about 20 - 30 minutes. keep an eye on the temp gauge also. Good luck!
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
04-30-2016, 06:23 PM | #3 |
On my Edelbrock 650avs the rpm is about 3000 when the idle screw is all the way in. I'd get it started and then make real suttle changes if you have to. If it's running ok when you fire it up and the temperature gauge says its normal, I'd leave it until you have that 20-30 minutes under your belt. Make sure your using break-in oil made for the break-in process specifically, especially if it's a flat tappet
04-30-2016, 06:36 PM | #4 |
the cam is slathered in breakin stuff and I added zinc additive to the oil.
I dont have a temp gauge though. Maybe I should hook one up before i start. |
04-30-2016, 07:08 PM | #5 |
04-30-2016, 08:00 PM | #6 |
Also, vary the RPM between 1500-2500 during the cam break-in. I ran mine with straight 30 weight oil with a ZDDP additive for about 20 minutes between 1500-2500 RPM and then tuned it. A temperature gauge is a must, and an oil pressure gauge would be a good idea as well. Don't let it idle to warm up, just fire it, verify oil pressure, and rev it up. I changed the oil after 50 miles to 10W30. Good luck!
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
04-30-2016, 11:26 PM | #7 | |
