Old 05-01-2016, 11:38 AM   #1
davepl
davepl's Avatar
Tilt column doesn't cancel going right
I bought a restored tilt column a year or more ago from a board vendor and didn't drive the truck until recently, only to find out the signal doesn't cancel returning from a right hand turn. Works on the left.
Is there anything special or different about a tilt? A friend said the spring breaks, and if I can get the spring out, I can replace just that. Or will I need to order a full turn signal for a tilt?
Put more simply, how do I fix it? What do I need?
Thanks,
Dave
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 05-01-2016, 12:32 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Tilt column doesn't cancel going right
Thanks,
Dave
The spring is either broken or one end has slipped out of the clip, or I have also seen the plastic clip break that holds the end of the spring.. You should be able to tell easily when you get it apart. No way to tell until you do.
LockDoc
Leon
Old 05-01-2016, 12:37 PM   #3
Wrenchbender Ret
There are 2 little springs you will see after removeing the steering wheel. One will be broken. Very common. You can get them as a pair at any parts store in the Help line.
Wrenchbender Ret is offline   Reply With Quote
Old 05-01-2016, 12:59 PM   #4
davepl
davepl's Avatar
Thanks! I've never had a tilt apart so didn't know what to expect or what I was looking for... handy forum as always!
