Old 05-01-2016, 06:48 PM   #1
Irishbleueyes
Help just found these in the rear end..
What the hell is this?? They were under the pinion down in the pocket. My pinion was making noise so I pulled it apart to rebuild it and the pinion was loose up and down. Went to set the pinion depth and it was 1/2 inch loose in and out just like it was when I pulled it apart and thats when I found these shims of some sort. Two of them are a little crunched.. Anyone know what they are or maybe my 12 bolt is some early one off?? It is a 65
Irishbleueyes is offline   Reply With Quote
Old 05-01-2016, 07:25 PM   #2
T and S
T and S's Avatar
Re: Help just found these in the rear end..
part of the bearing cage maybe ??
If you don't like this pound sand .....
T and S is offline   Reply With Quote
Old 05-01-2016, 07:27 PM   #3
Irishbleueyes
The bearings came out in one piece. I just don't understand what these are for..
Old 05-01-2016, 07:51 PM   #4
TJ's Chevy
TJ's Chevy's Avatar
Whatever they are they don't seem to be in to good a shape. lol
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 05-01-2016, 08:53 PM   #5
Irishbleueyes
Ya TJ, they're beat! I hope someone knows what the deal is, it's maddening!!
Old 05-01-2016, 09:00 PM   #6
donandal
that is interesting.
it's hard to tell how big they are.
what are the dimensions?
53 Chevy Pickup
donandal is offline   Reply With Quote
Old 05-01-2016, 09:23 PM   #7
Irishbleueyes
They are 1/2" x 1" about .020 thick
Old 05-01-2016, 11:20 PM   #8
Tazimafied
They look like clutch tabs from a posi that broke off. They would have been holding the friction plates in place with the carrier.
Tazimafied is offline   Reply With Quote
Old 05-01-2016, 11:23 PM   #9
mud.man.rj
mud.man.rj's Avatar
I would also say clutch plate parts, was a posi.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 05-01-2016, 11:52 PM   #10
Irishbleueyes
Wow, is that normal after many many miles? Looks like thats what it is. Thanks for any and all info..
Old 05-01-2016, 11:53 PM   #11
Irishbleueyes
I think it so.. damn
Old 05-02-2016, 12:06 AM   #12
Irishbleueyes
Ah figured it out, its off the end clutch plate cage. Thank you all
Old 05-02-2016, 12:11 AM   #13
Irishbleueyes
I assume theres 2 in there and all the tabs are broken off..
Old 05-02-2016, 12:36 AM   #14
Captainfab
60-66 Nut
That cage would be for the Dana/Spicer posi unit, not the Eaton style posi. Does your 12 bolt currently have a posi carrier in it?
Old 05-02-2016, 12:47 AM   #15
Irishbleueyes
Yes, it does have posi.. those tabs look just like that Dana cage, what are they?
Old 05-02-2016, 12:24 PM   #16
_Ogre
_Ogre's Avatar
well... technically not any more
shop air compressor timer
Old 05-03-2016, 12:18 AM   #17
Captainfab
60-66 Nut
The ears on those plates, keep the clutch discs and plates from beating up the inside of the carrier. Plus they now have a little more room to move around.
Old 05-03-2016, 06:28 AM   #18
vince1
They sure aren't horseshoes. Any damage to crown and pinion?
vince1 is offline   Reply With Quote
Old 05-03-2016, 10:30 AM   #19
Irishbleueyes
No damage to pinion, however the inside bearing on pinion pulled off without any resistance. So maybe it overheated. Pulling the cage apart today or tomorrow..
