05-01-2016, 08:06 PM | #1 |
Old member
Classic look... modern technology!
I have been working on my 71 installing cruise control for the 2016 HRPT in June. ls1nova71 has been nice enough to step me through the process along with suppling the needed parts.
One of the cooler things about this install is the cruise signal lever. It is a stock switch for a 72 Chevy truck with the upgraded guts. Hope to have it up and working after work tomorrow night. Here is the thread over in the LS section if you want to see what is involved with this install. http://67-72chevytrucks.com/vboard/s...d.php?t=703842
05-01-2016, 09:53 PM | #2 |
Re: Classic look... modern technology!
I bet your truck is one of the most comfortable and driveable trucks on this site Andy. You have so many cool mods done that really takes the comfort and daily driveability from newer models and put it in a classic. Cruise control is like icing on the cake
05-02-2016, 01:02 AM | #3 |
Very Cool!
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
05-02-2016, 05:06 AM | #4 |
Hmmm, And to think all these years I thought cruise control was Pink Floyd in the 8 Track and a Marlboro driving down the Blvd on my way to the drive in ?
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
05-02-2016, 06:33 AM | #5 | ||
Old member
My choice of cruisin music is Lynyrd Skynyrd though! But both work.
05-02-2016, 07:38 AM | #6 |
That'll be a very nice addition, cool...Ed...
1970 C/10 350/T5 SWB stepper... 1979 Corvette 350/Auto T-top... 2010 Acura RL... 2015 2500HD Z-71 Silverado... |
05-02-2016, 09:00 PM | #7 |
Old member
Got everything wired and ready to go tonight and it's raining so tomorrow night will be the test drive for it. Can't wait to drive it and see how it does.
05-02-2016, 09:13 PM | #8 | |
Absolutely, Andy just keeps on going,you would think after all those years one would be satisfied with what you have. But he just keeps Makin it better. That's a awesome mod dude,you drive your truck enough to use it so why not.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
05-03-2016, 06:21 AM | #9 | |
Old member
#1 I put Hagerty's insurance on it so I have a 5000 mile cap as of now. #2 Just letting it rest!
05-03-2016, 10:52 AM | #10 |
seriously this really is one of the best mods ive done to my truck yet.
I drive A LOT. since I bought my truck in November ive done 11k miles and having cruise just kills the highway miles. |
05-03-2016, 11:25 AM | #11 |
I wonder if I could make one work with my LS3?
05-03-2016, 12:21 PM | #12 |
05-03-2016, 01:03 PM | #13 |
Old member
The cruise is factory which for me is a cable hooked to the throttle. Mine is cable drive but he talks about wire driven throttle bodies too if it's drive by wire!
I'm sure he can step you through it like me. The picture is everything you need. Your wires are hooked to: #1- 12 volts with key on @ brake light switch #2- 12 volts when no brakes applied but no 12 volts when they are applied. #3- 12 volts when brakes applied #4- Ground #5- Vss signal from PCM in mine it was C-2 connector which is RED #50.
05-04-2016, 07:58 PM | #14 |
Old member
Drove the truck again today for the second test drive.
First drive was not so good. I got the cruise to work 2 times but then nothing. So after work I came home and checked all the wires out with only a test light. I found 1 connection bad and not working the signal wire on the brake pedal when released to the turn signal. It was interment so I made up another connection and what do you know I have a full functional cruise now. ls1nova71 is the man when it comes to LS stuff.
