Old 05-01-2016, 09:34 PM   #1
jhcolli
jhcolli's Avatar
Upper Control Arm spacing
Got my frame back from restoration shop to finish some work on it myself. Noticed the front it has significant amount of positive camber and I'm not sure these spacers/shims they put on are right. I haven't talked to them about it yet, but I'm guessing they did it to clear the x-member brackets underneath the control arm cross bar. Has anyone had to cut the bracket underneath for the control arms to clear it? I've already been in contact with Nathan Porter about how to adjust the camber, but after looking at several installations on the forum I've noticed the spacers on mine are the oddball.
jhcolli is offline   Reply With Quote
Old 05-02-2016, 09:16 AM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: Upper Control Arm spacing
I just got back in town this morning and sent you an email!
The spacers are too long. You will need to shim the arms to where the camber is zero at ride height. Just eyeball it for now... then once the truck is together you can have an alignment shop dial it in.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
