Old 05-02-2016, 12:14 AM   #1
1970stub
1970stub's Avatar
Custom frame rear body mounts
So my frame is custom and I just noticed that the rear body mounts aren't the same hieght. I'm leaning toward I need to fix them. Does anyone know how high the factory ones sit above the frame? Here is what I'm dealing with
1970stub is offline   Reply With Quote
Old 05-02-2016, 12:16 AM   #2
1970stub
1970stub's Avatar
Re: Custom frame rear body mounts
Which one do I fix? The high one or the low one?
Old 05-02-2016, 09:54 AM   #3
1rippen6
I may have the factory ones if you want to put them back on as far as the height I don't have a clue they are already cut off.
1rippen6 is offline   Reply With Quote
Old 05-02-2016, 10:46 PM   #4
Ta12sec
Can you add spacers to the low side to make it match
Ta12sec is offline   Reply With Quote
Old 05-02-2016, 11:58 PM   #5
1970stub
1970stub's Avatar
I'm already going to do ORD's 1" lift block to fix a completely different issue with the core support mounts. I'll search posts and try to find a picture of some rear mounts. Cutting one off and repositioning it isn't a big deal
Old 05-03-2016, 01:28 AM   #6
mcmlxix
Collector of Projects
mcmlxix's Avatar
Did you check the frame for square? They could be off because the frame is tweaked/twisted? If the frame is off, you're going to have a really hard time lining up all the body panels...
Rich
1972 K5 Blazer CST Click HERE
Old 05-03-2016, 11:13 PM   #7
1970stub
1970stub's Avatar
The frame is pretty square from looking at it but ill run a level and plumbob on it just in case. Looking through other posts last night it looks like they sit more than an inch above the frame. I might put a 1/2 spacer on the low one to compensate. I already have enough welding to do with boxing it
