Old 05-02-2016, 01:56 AM   #1
Fly By Night
Drip under drivers side dash
When it rains I get water drips that show up under my dash, does anyone know where this comes from? I'm guessing the front cowl where the door vents and heater get their air from?
Fly By Night is offline   Reply With Quote
Old 05-02-2016, 02:23 AM   #2
67chevy_hotrod
67chevy_hotrod's Avatar
Re: Drip under drivers side dash
Mine does the same thing but I haven't tracked it down yet.. Btw nice name choice. A fellow Getty lee fan
1967 Chevy CST 10
1969 Chevy C/20 Longhorn
1969 K10 Suburban
1972 Chevy Cheyenne Super 10 turned K30 (sold)
67chevy_hotrod is offline   Reply With Quote
Old 05-02-2016, 04:46 AM   #3
Grumpy old man
Grumpy old man's Avatar
Check the body seam under the dash ,that leak usually starts from the windshield seam at the gasket ,pull your cowl panel off to see the extent of the corrosion .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 05-02-2016, 07:11 AM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Drip under drivers side dash
I would say it's the curve in the windshield gasket. Look right in the center of the curve and you should see a small hole in your dash also which will let the drip into the floor as your picture shows.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 05-02-2016, 10:12 AM   #5
n33k0
My truck has the same leak, and I haven't found the source either. During really heavy rain I'll get a similar drip on the passenger side. I noticed that if I park the truck pointed up hill, the drip isn't as bad as when the truck is level or pointed down hill.
Nick
1972 Chevrolet C10 Stepside
n33k0 is offline   Reply With Quote
Old 05-02-2016, 12:08 PM   #6
Andy4639
Old member
Andy4639's Avatar
Windshield gasket. Water comes in behind it at the top corner then runs down the inside of the gasket. The dash has a hole in it in that curved area for it to drip to the floor.
Old 05-09-2016, 12:52 AM   #7
Fly By Night
Thanks Andy, fortunately I am do for a windshield so that sounds like an easy enough fix.
Old 05-09-2016, 12:55 AM   #8
In The Ten Ring
Sounds like GM was planning ahead with the hole in the dash!
In The Ten Ring is offline   Reply With Quote
