Old 05-02-2016, 10:58 AM   #1
dragn91
dragn91's Avatar
Thinking about bagging my crew cab looking for front bag setup pictures
Thinking about bagging my crew cab c20. I need to know how much I need to section the front crossmembers to lay frame instead of control arms on a c20 should be the same as a c30 as the frames are the same height. My plan is to use drop spindles m.m.w dodger upper control arms and cupped l.c.a's with a sectioned crossmember. I just traded into a fully bagged civic that I'm going to part out so I basically got all the air management for free just need to buy bags since the civic is on cylinders. Here's my truck it's an 80 crew cab with a 73 stepside bed on 22 inch transport steelies. http://
Ignore the positive camber the previous owner has like and inch of shims on the upper control arms I still have to align it.
dragn91 is offline   Reply With Quote
Old 05-02-2016, 03:25 PM   #2
bbbc10
Diggin The SquareLife
Re: Thinking about bagging my crew cab looking for front bag setup pictures
Section 1.5" out of the crossmember
bbbc10 is offline   Reply With Quote
Old 05-02-2016, 03:43 PM   #3
SCOTI
SCOTI's Avatar
A 1.5" sectioning allows the frame rails to hit the ground. The a-arm pivot points will be about 1" from making contact.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-02-2016, 04:39 PM   #4
dragn91
dragn91's Avatar
Thanks I thought that was the number just wasn't sure. And that is right for c20/30's right? I know the c10s have a shorter frame than the 20s/30's so I figured it be different
Old 05-02-2016, 04:46 PM   #5
slotard
The frame dimensions vary from year to year (or at least the section modulus according to GM Heritage Center pdfs varies), but it looks like all crew cab frames are 7.33. For some years single cab C20 and C30 frames have the same section modulus, for others they don't, and for all I know there are options not shown in the Vehicle Information Kits.
1973 C20, 350/350
slotard is offline   Reply With Quote
