Axle swap?
Gentlemen, I picked up a '68 C60 from a local salvage yard. Its a 366, 5 and 2 truck. I got it because it has 11.25 inch 10 hole axles and I'm thinking of swapping them over to my '72 so I can run 22.5s. I know i will have to address the obvious master cylinder differences because this axle has dual front wheel cylinders but other than that does any one know of any issues I may encounter? Thanks.
#2 | |
Re: Axle swap?
-Richard
I may have too many Chevys... Is that possible? ![]() 68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713 |
Re: Axle swap?
Here is the '72 and I will snag a pic of the '68 tonight. completely different bolt patterns.
Re: Axle swap?
I double checked my 68 and sure enough the fronts are single wheel cylinders with dual on the back. I was not aware that they did trucks as old as 68 with the larger bolt circle on he wheels, it is possible that those axles were swapped in from a newer truck but just as possible as some option that I've never seen, either way that is a great find. I spent around 1600 for a set of 22.5 wheels that will fit the smaller bolt circle.
Back to your question, the only thing besides the brakes that I can think of would be possibly a different size u joint and maybe a slightly different length drive shaft. Based on my experience between the 68 and 89 trucks just about everything is a bolt in swap. Your 72 is a good looking truck, what are your plans for it? -Richard
Re: Axle swap?
I bought the '72 at a auction last fall because I had just made a deal to do a dozer/tractor job that required a dump truck and while my '56 is a good truck I couldn't risk it going down in the middle of the job. Well she never failed and I ended up never using the '72 so I don't know what I'm going to do with it now.
Re: Axle swap?
I'm not sure it's a '68.
Re: Axle swap?
Here is the '56 on the job.
![]() Join Date: Jun 2005
Re: Axle swap?
You're set, it's a '68, as 1967 & 1968 were the only years with that particular "Bowtie over 40/50/60" emblem above the door hinge area, with the '68 having front fender marker lenses, while '67's are smooth. Also the V.I.N. shows the number "8" in front of your manufacturing plant letter of "S" (not sure which plant that is/was?). Gonna' be a cool truck!
Re: Axle swap?
Wow, thanks. Lucky guess.
![]() Join Date: Apr 2016
Re: Axle swap?
Hello everyone! I am brand new to this forum, and I will post my ride soon. But, this thread caught my attention.
Am I reading this correctly? If the truck has a 11.25 bolt circle diameter and 10 lug that new 22.5 rims will be readily available allowing a tubeless tire? |
Re: Axle swap?
Yep.
Re: Axle swap?
Good to know!
Sorry for my ignorance, but is it generally only C60's that have the 11.25 bolt circle diameter? No issues with the center hole size being too small or big to fit modern rims? |
#13 |
Re: Axle swap?
I would assume that it is a 60 only option but is seams like back in the day you could order any configuration you wanted. Expladv posted a sweet dump truck a day or so ago that had the same hubs but you don't see them to often. I haven't bolted a rim on yet but will be soon.
