Big Block Swap For Trailer Towing
Thinking about putting a big block in place of the 283 in my 1966 Suburban. Been towing a 27 foot dbl axle camper trailer and feeling the limitations of the 283 small block - "it's time to put a bigger motor".
Looking for comments regarding ease of fitment, references to example threads that may be out there, suggested motor/auto-tranny combo. Not looking for the Corvette super motor, just a good old fashioned big block with carburetor. |
![]() Join Date: Jun 2010
Re: Big Block Swap For Trailer Towing
Pretty much what we did...BBC/T400/D60.
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
![]() Join Date: Sep 2011
You will probably need to modify the firewall to get a big block to fit in there. One day I'm going to put up 350 in mine. Pretty much A drop in motor swap.
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
You do not have to modify the firewall. You just need to move the engine forward with either the '68-'71 big block engine mounts and brackets, or the '73-'87 engine mounts. The '73-'87 frame brackets from a C20/30 fit the earlier frames better than the C10 brackets.
I did not modify the firewall on my '66 Suburban, but I did fabricate some custom engine mount brackets that moved the engine forward about 2" from the original location.
Big block fits no problem either way as long as you use factory valve covers. Larger aftermarket chrome or aluminum covers will need more clearance. I am running 454/700r4 combo.
| Bookmarks |
