Old 05-03-2016, 09:10 AM   #1
dennislbrooks
dennislbrooks's Avatar
65-70 12 bolt rear axles turned for 6 log rotors and mount
I have a pair of good 65-70 12 bolt rear axles that have had the centers turned down about 3.125" for 6 lug rotors--I think around 73-80 K10 front rotors work and the mounts for caliper bracket mounts. These had 82 camaro rear calipers. You would still need the caliper mount which I probaby have the templates for. I can use but do not need these axles for the 46 chevy I am using the axle housing in. I have another pair of axles to use with drum brakes. Will not ship as you could have yours turned if needed . Just let me know if you want them. We can work something out. Can supply a pic if wanted.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
