Old 05-03-2016, 09:40 PM   #1
ItWillBeSlow
ItWillBeSlow's Avatar
crank pulley search
I am in process of acquiring power steering parts for my 72 c20, 350, short pump, non-AC, currently manual steer truck with a 1 groove crank pulley.
I am looking for a 3 groove, OEM style crank pulley in black as this is what is needed for this conversion (to my knowledge, based off my research here, please confirm?)
Im having a hell of a time finding a 3 groove pulley, in black, Summit has one shown but it has a disclaimer on it that it requires a matching water pump pulley or something another....
Where can I find a 3 groove black crank pulley for my 72 350???????
This is all i see on summit.
http://www.summitracing.com/parts/sum-g3972b/overview/
"This pulley must be used with either a SummitŪ or Trans-Dapt Performance steel water pump pulley for proper belt alignment."
1972 C20
ItWillBeSlow is offline   Reply With Quote
Old 05-03-2016, 10:30 PM   #2
Acorn
Re: crank pulley search
Check with some of the vendors that are on this site. Or better yet, become a premium member (best 25 bucks you will ever spend!) and place a Want To Buy on the parts board.
The bitterness of poor quality lingers long after the sweetness of a low price is forgotten.
Acorn is offline   Reply With Quote
Old 05-04-2016, 07:08 PM   #3
ItWillBeSlow
i hadnt searched every vendor due to lack of time, but expected a generic (and common) sbc part to be relatively simple to find and not likely offered at the 67-72 vendor shops, that may have been a bad assumption.
If anyone knows of a place to find one, please let me know If not i will continue the hunt
1972 C20
Old 05-04-2016, 11:36 PM   #4
swamp rat
swamp rat's Avatar
I cant guarantee it off hand but i think the 2 groove pulley on this page mates up with the stock inner pulley. I can verify the numbers of the stock pulleys later as i'm not home at the moment.
http://www.speedwaymotors.com/Lightw...evy,73980.html
http://www.speedwaymotors.com/Lightw...FY17fgodW7EN4w
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 05-05-2016, 10:27 PM   #5
ItWillBeSlow
Thanks swamp rat, this looks like a really good option
1972 C20
Old 05-05-2016, 10:33 PM   #6
Chevy Fan Always
Chevy Fan Always's Avatar
I have a set that I am going to use on a truck. I will check part numbers for you tomorrow.
Chevy Fan Always is offline   Reply With Quote
Old 05-05-2016, 11:09 PM   #7
swamp rat
swamp rat's Avatar
Sorry, i got home last night and went lights out in my chair then forgot today..
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 05-06-2016, 11:29 AM   #8
swamp rat
swamp rat's Avatar
This is an aftermarket stock replacement set i bought a bout 4 years ago, the inner pulley number matches my stock pulley so i don't have any reason to think that the number on the front pulley would be different.
Google 3744043 pulley and it will show some results.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 05-06-2016, 10:52 PM   #9
ItWillBeSlow
Swamp rat, the pulley in the top pic is the 2 groove, and lower is an oem single groove?
I noticed the part numbers in the link you posted and your upper pic are very close, but one digit off. However both appear to be sbc 2 groove pulleys. (3744043 vs 374403)
Thanks a ton for the help
1972 C20
Old 05-07-2016, 02:11 AM   #10
wbc409
Were the 3 groove pulleys a single piece? I remember pulling a couple sbc apart, and the 3 groove pulley was a separate 2 groove pulley in front of a regular single groove pulley against the balancer.
wbc409 is offline   Reply With Quote
