05-03-2016, 10:29 PM | #1 |
235 Center of gravity
I have my 235 on an engine stand. Had difficulty getting the arms on the stand to connect to upper and lower bell housing holes but finally got it configured.
I am going to make some shorter arms as it appears that the engine (standing straight up) is above the center of gravity. The center of the pivot is closer to the crank than the head. Anyone got a good idea where the rotating axis should be so that it does not flop over when I start to rotate? All I am doing is new gaskets and paint. Head is not coming off. |
05-04-2016, 12:23 AM | #2 |
Hollister Road Co.
Re: 235 Center of gravity
I don't use a newer stand on a 235.The dressed weight for a 235 is 660 lbs.
I leave it on a table on it side to do pistons and pans then set it in a cradle on the floor to put on the cylinder head. Less chance of getting hurt when you try to flip it |
05-04-2016, 07:04 AM | #3 |
That's why I asked the question. Should not be an issue if properly centered. I have had small block chevy (575 lbs) and 460 Ford (680 lbs) on this stand with no issues. Just concerned getting it in the proper position so that the weight properly distributed.
05-04-2016, 11:11 AM | #4 |
If you haven't already, go to
http://devestechnet.com This is a great site for the 235 and he actually shows a template he made for his Harbor Freight engine stand to solve the problem that you're talking about. He also has a PCV solution that eliminates the down draft ventilation and a full flow oil filter which replace the bypass filter(if you have one) as it filters less than 20% of your oil. Last edited by buckkoo; 05-04-2016 at 11:36 AM. |
05-04-2016, 11:31 AM | #5 | |
Allen |
05-04-2016, 01:05 PM | #6 |
You are on it. Just need to ask or used the search function. Stovebolts.com is another orientated more towards stock trucks.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
05-04-2016, 01:56 PM | #7 |
05-05-2016, 05:43 PM | #8 |
Buckoo, thanks a lot for posting that link to devestechnet.com/. I don't know how I have missed that site, but it is very informative for those of us who are keeping it stock. 58CameoAZ, it looks like a lot of stuff on there also applies to our trucks, for example there is a rebuild of a 1959 235 engine.
I can't see much of the site yet because my internet is acting up but it is already being listed in favorites! Thanks again....
57 suburban(sitting in the driveway), 2 69 C20 longbeds (sitting in the field ) and a 2003 8.1 Suburban Endeavor to persevere. "All of a sudden, I'm the old timer!" Some old timer on American Pickers. |
05-06-2016, 03:37 PM | #9 |
COG usually about the same height as the cam on V-8s, higher on 6-cyl. try it about half way between the cam and top of the block. should be OK after head install.
I did a 302 Jimmy for a guy awhile back. had to rebuild my engine stand completely. One of the main tricks is to extend the pivot. mine is now about a for long, turns any engine with ease. Rotate a SBC with one hand. |
05-07-2016, 12:25 PM | #10 | |
polishing a turd
Posted via Mobile Device |
05-08-2016, 08:25 AM | #11 | |
that looks like a pretty good spot |
