Old 05-04-2016, 11:51 AM   #1
54blackhornet
54blackhornet's Avatar
Once in a while you get lucky ?
When I bought my 71 GMC from the first owner I was disappointed to notice nine holes drilled in both doors. Three of the holes had rusty screws in them ? I determined that at least three different styles of mirrors had at one time been installed. After acquiring the driver's side sport mirror, backer, gasket and screws needed for the install ,I discovered three of the holes in the door where the factory holes for sport mirrors that where removed at some point earlier. Better yet the backer was still affixed in place on both doors. 15 minutes later after removing the rusty screws the driver's side mirror is in place, never even had to remove the inner door panel.......
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 05-04-2016, 03:07 PM   #2
Custom 68
Custom 68's Avatar
Re: Once in a while you get lucky ?
it just adds to the good looking patina...
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
