05-04-2016, 01:12 PM | #1 |
Wood bed bolts w/out the wood
I'm going to be putting my bed back on without the wood for now. Has anyone done this before? What type of bolts can I use to mount my cross rails to the frame w/out the wood?
Ideas? |
05-04-2016, 01:34 PM | #2 |
Re: Wood bed bolts w/out the wood
By bolt kit and get some wood or I used leftover scraps from old wood to properly space bed.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
05-04-2016, 02:28 PM | #3 |
It's Better With Nitro
I just used some leftover grade 8 hardware that is long enough to secure the bed cross rails to the frame mounts and the perimeter lip to the cross rails. you'll have to make a set of .75-inch spacers for the frame pedestals...
