Old 05-04-2016, 07:20 PM   #1
CG
BlahBlahBlah
Door jamb changes
Did the door jambs change in 71 or 72? In my head I see them basically the same until they added those vent thingies ... is this correct?
Old 05-04-2016, 07:29 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Door jamb changes
72 got the vent
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 05-04-2016, 08:05 PM   #3
Rod Run
Rod Run's Avatar
My 71 has the driver's side vent
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 05-13-2016, 01:36 AM   #4
CG
BlahBlahBlah
So basically 67-70 cabs are exactly the same except for the small back window in 67's
Old 05-13-2016, 06:20 AM   #5
Basically. The vent was only in some '71s and all '72s. The differences are '67-only dash (except some early '68s), e-brake set-up is 67/68 or 69-72, mirror bump in '71, VIN-plates changed in '70, A/C, headliner, cargo light, clearance lamp options, wiring/fuse block location changed. I think that's it
Old 05-13-2016, 06:37 AM   #6
NGN
NGN's Avatar
Special-K you mention headliner , what was the change.
Thanks Nick
NGN is offline   Reply With Quote
Old 05-13-2016, 08:28 AM   #7
All headliners are the same. It's a difference in the cab. I listed four options together that make a cab differ from the rest.
Old 05-13-2016, 10:14 AM   #8
68is4me
68is4me's Avatar
I also believe 69 started putting a location for a door jam switch, Not sure that is the correct starting year but I know 68 doesn't have it and I have seen it on newer cabs,
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
68is4me is offline   Reply With Quote
Old 05-14-2016, 08:35 AM   #9
The base truck had no door jamb switch. In Chevys, the 67-70 Customs, 67-70 CSTs, and 71/72 Cheyenne/Cheyenne Supers all got the switch
