Old 05-05-2016, 05:42 PM   #1
grc53
Dolphin Gauge retrofit help
Has anyone had any experience with the refitting your dash with Dolphin's 5 inch electronic gauges. If so I would love to see a picture and know what you think of the gauges.
grc53 is offline   Reply With Quote
Old 05-05-2016, 08:42 PM   #2
1952
1952's Avatar
Re: Dolphin Gauge retrofit help
check these guys out...New Vintage USA ....
1952 is offline   Reply With Quote
Old 05-06-2016, 07:42 AM   #3
Jemezcrusher
Nice gauges, but twice the price of the Dolphins
Jemezcrusher is offline   Reply With Quote
Old 05-06-2016, 08:00 AM   #4
grc53
I agree that they are more pricey than dolphin. Anyone have experience with dolphin in the last few years. I know they had a few lighting issued some time ago and wondering if it has been solved
Old 05-06-2016, 11:01 AM   #5
Iceburgh
Iceburgh's Avatar
I have used dolphins on 3 different builds. No issues at all. 2 had the dip switches that are a PIA to program due to getting your hand up behind them, but done once never have to do it again. The other was the electronic version and it was very easy to program as long as you have a area where you can drive 1 mile and be able to pull over or stop safely
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
Old 05-06-2016, 05:42 PM   #6
xaircav
xaircav's Avatar
I used Omega Kustom and they were a bolt in. (Made in USA too)
xaircav is offline   Reply With Quote
Old 05-07-2016, 05:50 AM   #7
grc53
Are the Omega Kustom electronic or mechanical? They have a good look!
Old 05-07-2016, 06:39 AM   #8
shrek55
Electronic
shrek55 is offline   Reply With Quote
Old 05-08-2016, 04:28 PM   #9
xaircav
xaircav's Avatar
Originally Posted by shrek55 View Post
Electronic
He's right. If you get them spring for the harness and save yourself a lot of splices.
Old 05-08-2016, 10:42 PM   #10
Lo1dakota
Lo1dakota's Avatar
Take the back half of your factory gauges and drill a hole to accommodate the Dolphin gauges. Weld the dolphin gauge brakets to the of the factory gauge back half. Slide the dolphin gauge through the factory trim ring then into the factory back half and tighten. Youll now be able to install the gauges just like factory.
Lo1dakota is offline   Reply With Quote
Old 05-09-2016, 12:16 PM   #11
grc53
Those look really good! I know that some vendors sell the gauges made so they fit right in the openings but they do not use the brackets already on the back of the dash. Your retro fit is a great idea. Thus far I have not had anyone talk about the reliability of the Dolphin gauges. Does anyone have comment on that?
Old 05-09-2016, 10:23 PM   #12
Lo1dakota
Lo1dakota's Avatar
Thanks!
I had a condensation issue on the accessories gauge. The heat from the bulbs made it condensate. They suggested I drill 2 eighth inch holes in the housing. I haven't gotten around to it yet since I took my truck apart for a rebuild.
