Ls swap help
I just picked me up a 68 c10 step side and wanting to put a ls 5.3 in soon, was hoping I could get sone help as to what motor mounts to use and what other parts I will need to do it as cheap as possible. Thinking of running a 700r4 behind it.. any help would be greatly appreciated
Post Whore
![]() ![]() Join Date: May 2015
Re: Ls swap help
The search function will tell you just about everything you need to know..
#3 | |
meowMEOWmeowMEOW
Re: Ls swap help
![]() SweetC10- your in the right place, but have a lot of homework to do! Search is great if you have specific questions in mind (try the "search this forum" tab instead of the big google bar up top). Its also worth having a look at the LS Faq, the "What Ya Got" thread, as well as browsing through member builds. The REALLY good info is hidden in those builds and topics, stuff like bolt sizes, obscure measurements and real-world feedback. Oh, and put together a real world budget. So many of our responses or suggestions at parts or services will relate to your goals and overall budget, so we'll be asking you for those sooner than later. *shameless self-promotion* You're welcome to checkout my build and/or my YouTube channel (links in sig). ![]()
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Re: Ls swap help
If you're going to do a 5.3 swap with a stock ECM I would at least go with a 4l60e and not the 700r4. They can be had for nothing because everyone doing 4l80e swaps dump them cheap.
Brew is right, the search function will help you find most of the answers you are looking for. Many different mounts you can go with, ways to do your own harness modifications, how to set up the fuel system and so on. If you have specific questions and can't find the info post it up in this thread. A lot of us have done these swaps, some many times and I am sure we can help you along!
Brandon Instagram: DRVFSTR Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691 |
Re: Ls swap help
If I were doing another swap, I'd get the engine and the 4L60E as a matched pair; the linkage for a 700R4 is more trouble than it's worth unless for some reason you want a carbed setup. (Which is not likely to be the cheapest option.)
The more stuff you DIY, the cheaper it will be. The lowest budget option out there would probably be to cut your own motor mount adapters out of steel plate and modify a stock 5.3 ECU / wiring harness, although that is a bit more hassle than getting a ready made mount kit and harness.
Matt Cramer 1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD 4.8 LS build thread |
Re: Ls swap help
Dirty Dingo has the mounts you need.
LS1Tech.com has way more information than you can imagine regarding that swap. Best value as stated is the 5.3/4l60e but bigger is better, meaning you come across a 6.0\4l80e combo, take it. If you are a true Diy'er then grab the entire vehicle. Suvs have drive by wire (a pain at times) where as the trucks and vans are drive by cable.
Science flies you to the moon; Religion flies you into buildings. LeMans Turbo build http://ls1tech.com/forums/forced-ind...rbo-build.html C10 build (twin-turbo) http://www.performancetrucks.net/for...didate-501987/ |
![]() Join Date: Apr 2005
Re: Ls swap help
If you get a DBW motor, this pedal adapter bracket works really well,
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=651123
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#8 | |
meowMEOWmeowMEOW
Re: Ls swap help
Re: Ls swap help
Thanks for all your replies guys.. hoping not to get in over my head but I guess we will see. She is my daily driver and the gas mileage with the 350 sucks haha
Re: Ls swap help
What's the best to do with the fuel system on the cheap? Getting little over whelmed. Will a online pump and the lmc rear mount tank be sufficient? With the vette regulator
Post Whore
Re: Ls swap help
I run a inline walbro 255 and the vette style filter/reg out of my stock tank..the return from the regulator goes back into the tank.. so you'll need a supply and return on your sending unit.
Re: Ls swap help
Can I do that same setup on the lmc rear mount tank or is that to far for the fuel to travel on the online pump?
#13 |
Post Whore
Re: Ls swap help
My pump and filter/reg is mounted right above my tank and i only have a supply line to the engine and i just capped my return rail..it works fine. I think there's about a foot of suction hose on it between the tank and pump..if your engine has a return rail fitting on it you can skip the regulator and just run a filter at the pump but you will then need a supply and return line from tank to engine
#14 |
Re: Ls swap help
Is there and sending unit yout can use that will work?
#15 |
![]() Join Date: Feb 2004
Re: Ls swap help
Pull a plastic camaro tank out of a 2000-02 camaro and mount it behind the axle. If you pull the pump out you can remove the regulator and use the stock regulator on the truck manifold. Then you have the option of the bolt in racetronix upgrade. That's what I'm running.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
