Old 05-05-2016, 10:55 PM   #1
Isaiah92260
Isaiah92260's Avatar
4:11 to 3:07 rear end
If I get a 3:07 rear end for my 250I6 w/ 3 speed... Do I need to change my drive shaft? Or can it stay the same length? Thanks.
Isaiah92260 is offline   Reply With Quote
Old 05-05-2016, 11:20 PM   #2
lumpy63
lumpy63's Avatar
Re: 4:11 to 3:07 rear end
If your truck is a c10 with a 12 bolt year end and you are just changing to another 12 bolt the driveshaft length is the same .Depending on the year of the donor axle the u joint could be different .
lumpy63 is offline   Reply With Quote
Old 05-05-2016, 11:22 PM   #3
Isaiah92260
Okay good to know thank you... I found one that is off of a 72... I have a 63
Old 05-05-2016, 11:26 PM   #4
lumpy63
lumpy63's Avatar
should be ok u joint should be #1310 same for both trucks
Old 05-05-2016, 11:28 PM   #5
Isaiah92260
Sweet! Hopefully I can pick it up!
Old 05-05-2016, 11:34 PM   #6
2manyprojects
2manyprojects's Avatar
I did this swap. The rear is a bolt in but annoyingly slow with the 250, just something to consider. There are other options to make it more fun to drive and keep the 250, like a overdrive trans. Having a driveshaft made is pretty cheap and T5's are too if you look around.
65 Chevy C10 Panel http://67-72chevytrucks.com/vboard/s....php?p=7148391
42 Chevy 3100http://67-72chevytrucks.com/vboard/s...92#post7184392
96 GMC K2500 Diesel Suburban
89 GTA Trans Am Convertible.
2manyprojects is offline   Reply With Quote
Old 05-05-2016, 11:37 PM   #7
Isaiah92260
Thanks for adding, I've been trying to weigh my options. I'm tired of maxing out at 65 with a screaming trans at 2700rpms. Plus I like to drive my truck on 2 hour drives to visit family.
I've heard about the T5... I've been thinking about it, I havnt had any luck finding any s10 versions, mostly canaria that require the modifications, plus a couple dues wanted too much..
Old 05-05-2016, 11:47 PM   #8
2manyprojects
Ive bought several S10 T5's for $100 on Craigslist and at the local pull your own junkyard. They are out there just keep looking. The 3:07 is driveable but just don't expect to accelerate quickly.
Also a 700r4 will bolt to it if you wanted to go automatic I did that swap too and loved it.
Old 05-05-2016, 11:53 PM   #9
Isaiah92260
My local junkyard didn't have any t5, found a few beater s10's but had automatics, Craigslist has been a dude lately, I've been trying to keep a eye on it ....I was thinking about going for 700r4 too but not sure yet if I'm confident enough to tackle the whole conversion, I know I need to get the oil cooler or a new radiator for one, steering column cuz I don't want to put the shifter on the floor, and not sure how well a tv cable would work for a straight 6
Old 05-06-2016, 12:15 AM   #10
2manyprojects
The 700r4 isnt too difficult feel free to ask questions if you decide to do the swap.
I used the TV cable bracket from the 305 I got the trans off of and modified it to work. The TV cable adjustment is critical or you will burn the trans up other than that its not hard at all and worth doing.
Old 05-06-2016, 12:23 AM   #11
Isaiah92260
Thank you so much, I'll keep it in mind. I seen one for $200 about a hour away from me, maybe I'll look into more
Old 05-06-2016, 12:35 AM   #12
vince1
72 I believe will be 5 stud and the panhard bar setup is different but doable. It will also be 1 1/2" wider and IMO looks better.
vince1 is offline   Reply With Quote
Old 05-06-2016, 12:41 AM   #13
TJ's Chevy
TJ's Chevy's Avatar
3.07 is a bit steep, but will work. Engine has enough torque. I'd personally do a 3.42.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 05-06-2016, 01:48 AM   #14
60chevyjim
60chevyjim's Avatar
in nc everything is so far away and the speed limit is 65-70 MPH.
so I love having 3:08 rears in my trucks ,
my 97 S-10 has A 4.3 V6 5spd and 3:08 gears
and my 93 GMC that I put A old carbureted 454 with a th350 in has 3:08 gears .
I use both of them for towing too.
I would hate to have any other gears is either one of them .
my 65 C10 is going to have highway gears too.
60chevyjim is offline   Reply With Quote
Old 05-06-2016, 10:23 AM   #15
verdell
verdell's Avatar
I'd consider the 3.42's also...
verdell is offline   Reply With Quote
Old 05-06-2016, 01:25 PM   #16
Isaiah92260
Is it possible to swamp out the gears I have in my differential to a 3.07 or to a 3.42? And if so, Someone like me with no experience can do it, or should I go to a professional?
Last question, ha.... What are the characteristics of the 3.42? How would that run like with a 250i6/3Speed.
Old 05-06-2016, 01:56 PM   #17
TJ's Chevy
TJ's Chevy's Avatar
For a bone stock 250 3.42 would probably drop your RPM's to 2500 at 65. You say 2700 rpm at 65? That sounds more like a 3.73 ratio, and if you have that ratio I'd consider an OD trans Or taller tires. My 64 GMC has 4.11's and 2600 RPM is 55 with 31 inch tires.
I'd consider 31 inch tires for yours and see what happens. That should be 2 inches taller than what you have right now. Bout 10 miles an hour faster per inch taller tire.
Old 05-06-2016, 02:55 PM   #18
Isaiah92260
No you are about right, I was heading up the hill to work about an hour ago and I was hitting 2500 at about 60, not sure if it was because I was going up a hill tho... I was making a ruff estimate when I started the thread...I don't know that exact ratio on my differential, I have pretty small tired that the PO said were new. Shoot maybe 31" might get me up at 70 ish at 2500 rpms then, I gotta find some prices on them now!
Old 05-06-2016, 03:53 PM   #19
padresag
well that s10 be lighter than his c10 and the engine is more than likely a little snappier. and that 454 with a 350 trans will work wonderful with the 3,08. think there might be apples - oranges on that one
ron
padresag is offline   Reply With Quote
Old 05-06-2016, 04:25 PM   #20
TJ's Chevy
TJ's Chevy's Avatar
Yeah, 31's will at least help. And a wide variety of 15 size tires are out there. And for a 6 banger...2700 ain't to hard. Passing people I left mine at 3000. lol But since it is old, 2500 or a bit lower will be easier on it.
Old 05-06-2016, 09:54 PM   #21
vince1
The gears will not swap over, something about series 2, 3 or 4 carriers and different crown gear thicknesses.
Old 05-06-2016, 10:11 PM   #22
O'larry
O'larry's Avatar
I think series 3 is 3.08-3.73 series 4 is 3.90 and up if I remember right
O'larry is offline   Reply With Quote
