Brakes
Doing a 64 with ridetech suspension. Kit came with CPP drop spindles. Does anyone know what aftermarket brakes will work with those spindles? I am using Capt fab's set up in the rear with 95 impala SS brakes. I would like to do the same for the front. I really can't afford the big name kits and i don't need anything fancy for my application
Thanks in advance, Joe |
![]() ![]() Join Date: Oct 2014
Re: Brakes
Go down to page 253. There are some Mustang II big brake kits. I think, but am not certain, that CPP uses an MII type spindle. Give them a call and see if this will work for you. http://www.classicperform.com/Catalo...Mustang-II.pdf
Never Ending Projects
Re: Brakes
If they are CPP truck spindles, you can use any factory '73-'87 1.25" thick rotor setup (on later models this was the HD package, earlier were standard, no thin rotor option). This will make it 5 lug. With the spindles, you can use all factory, off the shelf parts.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#4 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Brakes
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Brakes
Unless the spindles are their modular spindles, you are stuck with stock type C10 brakes. To be able to use the 1.25" thick rotors, they have the be the correct spindle to accomodate those.
Re: Brakes
Thanks a lot guys, I believe they are the modular spindles according to what I was told from ridetech and cpp. I am going with the 1 1/4 rotor off of a heavy half and see if it works.
