Old 05-06-2016, 09:06 AM   #1
dmw319
Arrow Headlight switch gone bad?
So my brake lights work just fine, but when I put my headlights on, the brake lights aren't working anymore. Is the switch the most likely culprit?
1970 Chevy C-10 Stepside
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167
dmw319 is offline   Reply With Quote
Old 05-06-2016, 09:42 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Headlight switch gone bad?
I would say most likely bad grounds.
http://67-72chevytrucks.com/vboard/s...d.php?t=422234
LockDoc
Leon
Old 05-06-2016, 10:03 AM   #3
dmw319
LockDoc
Thanks, I will check these.
Old 05-06-2016, 10:35 AM   #4
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
LockDoc
X2 on the grounds. I would clean and check them all.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 02-07-2017, 11:02 AM   #5
dmw319
So bringing back this thread.. it seems that my left brake light is intermittent. Sometimes it works, sometimes it doesn't. This also affects my left blinker. On my instrument cluster the left blinker is sometimes lit up already so my left blinker lights don't function correctly. Then other times it seems to work normally.
Could this still be a grounding issues? I have purchased 3 ground straps and plan to redo them all.
One question I have: are the rear taillights grounded anywhere to the frame? Anyone have a picture of their wiring back there to show me what it should look like?
Thanks!
Old 02-07-2017, 11:24 AM   #6
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Headlight switch gone bad?
Thanks!
Do you have the cluster grounded? I would add a ground to the cluster while I was checking on the ground issue.
Also check the rear light housing and make sure they are grounded good through the housing screw's.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-07-2017, 11:29 AM   #7
dmw319
I assume the cluster has a ground stock? I haven't added anything extra.
fyi here are the lights I have:
Old 02-07-2017, 11:46 AM   #8
Andy4639
Old member
Andy4639's Avatar
Lightbulb Re: Headlight switch gone bad?
It should but that doesn't mean it does! I just went through this with mine. LED's need to be right also. No wires crossed. Regular lights don't care. Also if you put the LED's in front you need flashers for them.
Old 02-07-2017, 11:55 AM   #9
dmw319
thanks, just sick of the left blinker not working consistently all the time.
Old 02-07-2017, 12:00 PM   #10
LockDoc
LockDoc's Avatar
Thanks!
Yes it could still be a grounding issue. Did you read through the link I posted earlier? I know it is three pages long but there is good grounding info all the way through it..... The bed should be grounded to the frame and the lights are grounded to the bed.
The picture below shows where the cluster ground connects to the dash and where the wire connects to the cluster plug.
LockDoc
Leon
Old 02-07-2017, 12:05 PM   #11
dmw319
LockDoc
Yes, I did read the link. That is what prompted me to buy the ground straps, just haven't put them in yet.
Thanks for the pic of the cluster grounding!
Do you happen to have a pic of where the lights are ground to the bed? I have a feeling that may be my missing ground.
Old 02-07-2017, 12:22 PM   #12
LockDoc
LockDoc's Avatar
No picture, but if memory serves me correctly they ground through the tail light housings and screws, except for the lighted side markers, they have their own ground wire. Make sure the housing is clean where the screws tighten up against the housing on the inside, or go ahead and put ground wires on them.
LockDoc
Leon
Old 02-07-2017, 12:30 PM   #13
dmw319
LockDoc
thanks. ill have to take some pics of my taillights/wiring and post them here. I don't see any noticeable grounds.
Old 02-08-2017, 04:56 PM   #14
dmw319
I rechecked my grounds and everything seems to be correct.
Here is a video of the issue. When I put the lights on, the left blinker only (not the right one) turns part way on. Help!
https://youtu.be/M4c3zyJ_Ijg
Old 02-08-2017, 05:13 PM   #15
randy500
No blink is usually a bad bulb. I believe the blink comes from heat build up in the flasher causing the bi-metal to bend, the bad bulb doesn't create enough current flow to heat the bi-metal, hence no flash. Bad bulb or bad ground. Use a test light on the socket to see if it blinks.
The taillight housing grounds through the screws to the bed and the bed to the frame through the bed bolts. That path could be compromised by paint, etc. Also the taillight housing where the bulb goes in has a brass insert and that insert can become corroded between it and the taillight housing which interrupts the ground path. Check with a test light grounded at that location checking power at the bulb pins in the socket. Then check using a good ground to the bulb pins.
Sometimes people install a heavy duty flasher too which prevents a good blink, the heavy duty one is for towing and slows down the flash due to the extra load from the trailer lights. You could try exchanging the 4 way and normal flasher to check that.
randy500 is offline   Reply With Quote
Old 02-08-2017, 05:18 PM   #16
dmw319
Thanks Randy. What is strange is that it blinks on and off normally if my headlights are off. When the headlights are turned on is when I run into the issue.
Old 02-08-2017, 05:27 PM   #17
randy500
I forgot about the change with the headlights on, I think the headlights may be getting a false ground through the marker lights. Each headlight has a ground strap about 6 inches away to the core support. Check to see they are both good, the ground path for that circuit is core support to RH inner fender which has a ground strap to the frame. The frame is grounded through the 2 ground straps on the firewall to the engine valve cover, check that too.
No LED bulbs right? Those cause havoc with the flasher.
Check that all bulbs are the same brightness headlights on and off, if one is dimmer it indicates a ground problem or a marginal or bad bulb.
Old 02-08-2017, 06:02 PM   #18
dmw319
ok maybe this will help.
this is my what my taillights are plugged into. 2 wires are connected and 1 is cut and not in use. its like this on both sides. any idea what its for?
when i pull back my battery on the passenger side, this is the ground, looks ok to me?
ground on the driver side:
valve cover, driver side. missing a ground clearly, but where should it go into on the firewall?
valve cover, passenger side. also missing a ground, there is a hole in the firewall but its directly behind the center of the engine. what should i do with this side?
Old 02-08-2017, 06:08 PM   #19
randy500
I haven't had too many stepsides so not sure on the connector, someone will chime in on that I'm sure, you could check continuity between the cut wire and the taillight housing to see if its the ground.
Headlight ground staps pictured are connected correctly, possibly dirty connection of paint interference.
Valve cover ground straps go to firewall and install with 3/8 head sheetmetal screw.
Check the ground strap under the battery from frame to inner fender.
And ground the engine to the cab, somehow.
Old 02-08-2017, 06:11 PM   #20
randy500
Is there a ground strap on the negative battery cable? Usually not I think, so if that is the case the ground path to the lights is through the engine to the transmission to the driveshaft then the rearend through the springs...not a great path.
Old 02-08-2017, 06:12 PM   #21
dmw319
Any pics on that one? I have a big rusted out section right where you are talking, so that could be my culprit.
Old 02-08-2017, 06:20 PM   #22
dmw319
no, i do not believe there is.
Old 02-08-2017, 06:26 PM   #23
randy500
I was gonna say something about that rust fender, I saw it in the picture, the ground strap is probably there, its a little rearward and by the frame, you could make some ground wire with ordinary wire to ground the core support to frame and the engine to the cab. The front turn signal housing can corrode inside too like I described on the taillight housings.
Use a test light like I described from housing to light bulb pins, kind of difficult to do though.
Old 02-08-2017, 06:29 PM   #24
dmw319
a pic would really help, cause i am 99% sure I do not have a ground strap in the location you are referring to. ill take a pic to show you what i mean
turn signal housings all look good.
Old 02-08-2017, 06:34 PM   #25
randy500
The ground strap can be seen from underneath, attaches like the firewall with a 3/8 head sheet metal screw. Then to the frame with a regular bolt.
Turn signal housings can look good but have corrosion in that sleeve insert which the bulb locks into preventing the ground path. I just had to re-do my dodge dart taillights for this corrosion I am talking about, had to remove the bulb connector and put in a new universal one, only had blinkers sometimes if the bulb was in just the right spot, hit a bump then no blinkers.
