![]() Join Date: Feb 2016
66 C10 New Suspension
any consideration which vendor is better:
Looking at Performance Online, Western Chassis and CPP. any insight would be great. thanks Keith |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: 66 C10 New Suspension
Personally I would stay away from CPP.
Look at the Vendor Reviews section here on the board. Lots of complaints! Call one of our board vendors like Pro Performance or use ECE at www.earlyclassic.com.
cool, thank you!
Moderator
![]() ![]() Join Date: Aug 2011
POL and Western Chassis are owned by the same folks. In fact if you go to the POL store in Carona you can see that and talk to them also (I have).
I have been going with their stuff. However I did purchase the Early Classic rear panhard bar for my 64 as almost no one else is concerned about the difference in frame mount positions from 65 on.
My wife ordered me some parts from POL. Drop blocks, deluxe track bar and 2 piece bolt on c notch. The track bar and finish look great. The c notch I have yet to install but looks quality made and has a nice black finish that came with all the hardware. I am happy with the products delivery was very quick, nothing was missing. The only thing I would have liked is more detailed directions for the notch, but over all I'm happy with the products. Good luck with your build.
Hhm. Thanks for the advice. What is a c notch?
I have CPP lowered springs front and rear, CPP c notch, and POL adjustable panard bar and shock relocation brackets. they all work fine. -Jimmy-
NOMADSC.C. ![]() |
Moderator
Ohhhh William.
C/10 Rene 1966 Short Fleet "The Hag" 1967 CST Short Fleet "Dark Poly" 1971 Short Fleet 1970 Jimmy Custom 2 WD "Golden Ticket" 1972 Blazer 2 WD "Retro Blaze" |
I used cpp for my 65 build. Did complete big brake package along with the complete suspension package,trailing arms,shocks,springs. Everything was bolt on. Good quality. Install went flawless. They also have on-line install directions for all the parts they sell. Prices are also low , I shopped around for all the parts. Couple of draw backs . I am in Ill. and it takes a week min to ship from Ca. And make sure you order the right part! They charge a restocking fee.. I think 20%. Other than that they were very helpful during the whole process. I would use them again.
when I order the ball joints and tie rods, I can stick with the stock parts? correct?
![]() Join Date: Aug 2014
Ive used CPP and POL and been satisfied with both. Also heard good things about ECE though. I have CPP sway bars with POL control arms and lowering springs and they sent me western chassis shocks with lowering kit. If I order CPP parts I always go thru Summit Racing though to prevent any shipping problems.
1965 C10 LS2/4l70, WHITE, 5/7 DROP LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283 1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E 1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE |
#13 |
Or you could use Rob at No Limits.
I have his front and rear ARB's and shocks, panhard bar and am very happy with the fit and price. However hsi customer service is beyond reproach. I was mistakenly sent a pair of incorrect shocks, he sent a replacement pair free of charge including duty and shipping to the UK, and I got them within a few days. No quibble. P. ![]()
Woody's Build - http://67-72chevytrucks.com/vboard/s...d.php?t=658621 If it goes wrong, I blame the Internet... |
#14 |
I have hotchkis on my truck. Handles like a car now.
#15 |
Great
Thanks for the info Any comments on stock ball joints and tie rods ? |
#16 | ||
YES you can use stock tie rods and balljoints as long as they match the spindle you use. (so in your case,... you would need 63-70 conversion spindles up front if you plan to go to disc brakes) Are you lowering your truck? Switching to discs? Replacing cross shaft bushings on the a-arms? Idler and pitman arm? New coils? Drop or stock? I guess we need more info.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 05-09-2016 at 08:29 PM. |
#17 |
Oh sorry
Thinking 2.5 drop spindles with front disc Staying with stock BBC front coils. Im using 72 c10 coil since same size. Im installing a 396 Then thinking 4 inch drop rear coils The 12 bolt rear is already from a 72 but wanting to convert that to disc as well Wasnt sure what to do next. I did save the center link Someone had started a front disc standard conversion but im starting from scratch |
#18 | |
You really only need your '72 centerlink if you plan to use 71-72 spindles and tie rods, which would require 71-72 balljoints. What about power steering? I still like ECE for suspension parts and customer service. Belltech, Western Chassis, and McGaughy's are great also. You have a lot on your plate. Rebuild the entire front end with quality parts. Do the same with your drop components and brakes. If you can't afford it, wait until you can.
#19 |
Post Whore
![]() Join Date: Mar 2013
I got the suspension kit from Classic Parts of America. I'd give it a 4 star.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#20 |
Great
I think i got it figured out now Thanks |
