Old 05-07-2016, 01:11 PM   #1
yoshi
yoshi's Avatar
Ford 9" axle
I decided it was time to fit the pinion seal that I ordered about a month ago. After reading & watching videos on how it's done I bit the bullet & removed the seal only to discover the new one is too big, my supplier said it's the seal that they always use. It's 1/4" too big on the o\d. Any idea what's going on, why is mine not the normal size? Thanks
yoshi's 49 project
yoshi is offline   Reply With Quote
Old 05-07-2016, 01:56 PM   #2
Speedbumpauto
Speedbumpauto's Avatar
Re: Ford 9" axle
What they probably gave you was a 7044NA seal which fits most 9" rears. The one you need fits "small" 9" rears made in the late 80's. The part number is 3604, I think. You should be able to get the specs on both from the net and see which matches your old one.
Speedbumpauto is offline   Reply With Quote
Old 05-07-2016, 02:21 PM   #3
yoshi
yoshi's Avatar
Re: Ford 9" axle
That's very helpful many thanks, any idea which vehicles these were typically fitted to?
yoshi's 49 project
Old 05-07-2016, 02:57 PM   #4
Speedbumpauto
Re: Ford 9" axle
I think they were in the last mid 80's pick ups before Ford converted to the 8.8 rears on all their full size stuff, but that's just a guess.
Old 05-07-2016, 08:32 PM   #5
mphudak
Re: Ford 9" axle
This might shed some additional detail
http://www.ford-trucks.com/forums/77...ification.html
55.1 GMC Suburban Hydramatic
mphudak is offline   Reply With Quote
Old 05-08-2016, 05:03 PM   #6
yoshi
yoshi's Avatar
Re: Ford 9" axle
Thanks but not really
yoshi's 49 project
Old 05-08-2016, 05:52 PM   #7
mr48chev
mr48chev's Avatar
Re: Ford 9" axle
If you didn't damage you old seal too bad you might be able to get the number off it or a bearing house or parts house can measure and match it.
If you can get the number off the old seal post it and I or someone else will interchange it and see if we can give you some seal numbers to hunt with
My ongoing truck projects:
Old 05-08-2016, 06:29 PM   #8
yoshi
yoshi's Avatar
Re: Ford 9" axle
Thanks, speedbumpauto has given me a number of 3604, my seal has a-9362 on it.
yoshi's 49 project
Old 05-10-2016, 05:42 PM   #9
yoshi
yoshi's Avatar
Re: Ford 9" axle
I managed to get a 3604 & now I'm up & running again, many thanks
yoshi's 49 project
