Old 05-08-2016, 12:17 AM   #1
71_Burb
what radiator
I have a question as far as radiator and fan used on the LS swap
I see a lot of people using aftermarket radiator, I havent measured yet but can you use the stock LS radiator in a 1971 c10 suburban ?. I ask this because I will be taking everything I can take from my 00 Silverado when I do my swap
Thanks Dave
71_Burb is offline   Reply With Quote
Old 05-08-2016, 12:51 AM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: what radiator
On mine I just kept my orignal trucks radiator. Although I did buy a new one..its plenty enough for cooling the ls..may be a lot involved in trying to fit a truck radiator in your burb.
Old 06-05-2016, 11:13 AM   #3
SparkyRnD
SparkyRnD's Avatar
Re: what radiator
If you are still looking, we hand-make aluminum radiators here in the USA using domestically sourced materials, and no plastic / epoxy / glue is ever used. And, we are a site sponsor here:
http://67-72chevytrucks.com/vboard/s...d.php?t=590670
www.RnDFabrication.com
Custom Radiators, Valve Covers and Overflow Tanks
SparkyRnD is offline   Reply With Quote
Old 06-06-2016, 10:08 PM   #4
dec010974
dec010974's Avatar
Re: what radiator
I used a stock radiator from 1985 Chevy C10. I bought from advanced auto parts. I also made my own fan shroud from pieces of aluminum, had a buddy weld the pieces together, and mounted some JY fans from a late 90's Pontiac sun fire. Between radiators and fans I spent about $200.00. Good luck.
dec010974 is offline   Reply With Quote
Old 06-08-2016, 01:11 PM   #5
LS short box
Re: what radiator
My .02 is that it's nice to have the radiator inlet on the passenger side so you don't have the upper radiator hose running across to the drivers side. Gives you a lot more room for the air intake tubing. If you are buying a new aluminum you go with a cross flow design the has both inlet and outlet on the same side or use a Ford style radiator that has the inlet on the passenger side.
It means the lower hose will run across at the bottom of the radiator but it's out of the way.
LS short box is offline   Reply With Quote
Old 07-20-2016, 12:55 AM   #6
72MARIO
72MARIO's Avatar
Re: what radiator
Any part numbers or vehicle model's to look up for the suggested hoses ? Having a nightmare with my new rad trying to find hoses. I have a rad with outlets both on the passengers side.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 07-20-2016, 11:18 PM   #7
72MARIO
72MARIO's Avatar
Re: what radiator
Well I have been keeping my old 1996 4.0 6cyl Jeep Grand Cherokee for a few years I couldn't see scraping it yet..
Turns out the hoses are a PERFECT fit for my LQ4 truck engine and ls swap rad with outlet and inlet on passengers side
2005 TAHOE DD
Old 07-21-2016, 10:03 PM   #8
nobox351y
Re: what radiator
I used the stock 87 burb radiator and 01 silverado hoses. Stock 87 shroud, 01 belt driven fan. The shroud could be another 1" longer to cover the fan, but I havent had any heat issues.
nobox351y is offline   Reply With Quote
