My 64 needs your help.....
Hey guys, Ive been working and working on this truck to get her going again and friday night I made another test drive but didn't make it more than a block away and had to come back home. It was popping through the carb and was very sluggish on acceleration. The truck has a late 70s 305 with a 4 barrel carb. I have installed a rebuilt mid to late 70s quadrajet, changed the intake gaskets and put a skip white racing HEI distributor w/adjustable vacc advance about a week ago. The timing was set to 10 deg with vac hose undone, just to start. I'm on manifold vac. When I got back, I set the timing back down to 6 deg but it seemed to run rougher. Then I started pushing the gas pedal down about 1/2 way over and over real quick and it wanted to die. Give it 1 good hit and it does o.k.
What I can't figure out is do I have a fuel or ignition issue? The only thing I haven't checked is my fuel pressure (I'll do that tonight). If my fuel pressure is good, what should I check next? |
Chevy addict
Re: My 64 needs your help.....
Check the rubber fuels lines, if they are original to the truck they may be collapsing when the engine calls for fuel.
64stpside
If you didn't have this problem before installing your Skip White racing distributor I would change out your distributor. There's a reason a Skip White distributor is $39.50 and a Mallory or Accel distributor is around $200.00 a friend of mine bought one of those inexpensive distributors and had the exact same problems you are having. He spent the money and bought a good Mallory and had no more problems. Another thing I learned when setting the timing on a motor I plug the ported vacuum to the distributor hook my vacuum gauge to a manifold vacuum port and rotate the distributor back and forth until I get the highest manifold vacuum I can at idle. I then take the vehicle out and romp on it. If I hear any pinging at all I retard the distributor until the motor quits pinging under full load throttle. I had a 71 Stage 1 GS Riviera that timing this way made a HUGE difference in power & performance but on a 73 Tornado it put me exactly at the specified setting. On my 64 C-10 with a 350 I'm about 4 degrees advanced from the factory specs. Again I would install a known good distributor before going much farther and see if your truck runs any better. |
I made up new hard line from the tank to the fuel pump and from the pump to the carb when I installed a new gas tank.
Some things I was told to check from some buddies this morning: 1. check the firing order/check for swapped plug wires 2. change to ported vacuum 3. start at 0 deg initial timing and work my way up. If it's not a firing order issue, they think the manifold vacuum + the 10 deg initial timing is causing the issue as running ported vacuum will cause the advance to come on with the throttle. Plus having no egr will cause me not to be able to boost the initial timing as much. |
#5 | |
Tell us a little more about the engine. Has it ever been rebuilt? Popping through the carb is a classic symptom of a worn cam or misadjusted valves. It could be the firing order or timing too. You might try adjusting the timing by ear in case your balancer has slipped or something. I have never had a distributor partially run. It is either dead or working. I have 5 Skip White distributors with no failures yet. You can get a dud with any brand.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
#7 | |
I need to back up a bit. I drove the truck about a 1/2 mi down the road when I bought it as it had a VERY VERY worn out mr gasket floor shifter....lol. When I started going through the truck I was replacing a lot of parts as I didn't know the age of them. The distributor I said had no vacuum advance was one I got not knowing the condition but it was cheap (lesson learned). The truck never popped through the carb before but it still wasn't right. Maybe the old distributor was in better shape than I thought... The truck was brought home on a trailer and I have been working on it since last summer and am just now trying to get it out for the 1st time. |
You might need to verify your timing marks.
http://www.crankshaftcoalition.com/w...op_dead_center Once that's done then put some timing in that smog 305. Start at 14 initial. |
man. sounds like you have it worse than I do. But, I do believe an open ported vacuum port was my driveability issue the other day. I didnt however have the popping back thru the carb.
Most of the guys here that are used to these engines would probably have no problem with the troubles we are having. But for me, not knowing anything about them, its a booger. make a change. go to the internet for help. make a change. back to the internet for help. the struggle is real. Good luck. |
#10 | |
*** That's interesting ***
Try 14 degrees initial (vacuum advance unhooked and capped at carb, engine running at idle, warmed up, no choke). Take the test drive with vacuum advance still unhooked. If it cures the popping, then it's a timing problem. You can always back it off if you hear pinging. Once we sort out what the base timing needs to be for your engine, we can re-introduce your vacuum advance. I also agree with checking and rechecking firing order (plug wire routing)! And confirm TDC. Every engine is different. What worked for one guy may not work for you. And giving advice in a forum is very difficult since there is a standard set of troubleshooting techniques one must run through each time a problem like this crops up.
Tom ![]() Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... |
I have the same low priced ebay hei distributers in at least 4 or 5 of my cars and trucks and never had a problem with any of them ever !!
I never use a timing light to set the timing on anything I own . your rebuilt carb could possibly be a problem ? or trying to set the timing to a certain degree # could be a problem also . I have never had any luck setting timing with a timing light . what the book calls for the timing to be most of the time will make the motor run like crap. |
#12 | |
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
#13 |
lol........guys......I had #6 & #8 plug wires swapped at the distributor!!! Could have sworn I had it right before. I do have another question that's been beat to death. I had it on manifold vacuum and was told to change to ported. When I did that I could NOT get rid of the black smoke not matter what. I even had the mixture screws out only 1 turn. Set the initial timing at 4 to start then to 6 and it's at 8 now and that didn't help. I know I've been told to crank it up but have also been told that due to no egr vale, I will get pinging due to no exhaust gas to cool the charge.My understanding is that ported was done for emissions.......period......but makes the motor run like crap. My question is, if you have a carb issue, will going to manifold vacuum cover up the symptoms? I want to make sure my carb is right and I not using manifold vacuum to make things work.
Regardless of my carb being an issue, I'm going back to manifold vacuum tonight unless someone can give me a reason not to. From another site about ported vs manifold from a GM engineer: ......(regarding ported vac) "This was done in order to increase exhaust gas temperature (due to "lighting the fire late") to improve the effectiveness of the "afterburning" of hydrocarbons by the air injected into the exhaust manifolds by the A.I.R. system; as a result, these engines ran like crap, and an enormous amount of wasted heat energy was transferred through the exhaust port walls into the coolant, causing them to run hot at idle - cylinder pressure fell off, engine temperatures went up, combustion efficiency went down the drain, and fuel economy went down with it." |
#14 | |
Everyone has been great on here and we'll get 'em right......just be patient. I got so mad sat night I wanted to sell it.....lol. |
#15 |
Using manifold vac will help your carb run right. With manifold vac hooked up, your idle increases and then you can turn it back down and get your carb idling on the idle circuit and not the smoky black power circuit. It all has to do with the transition slot.
There's a section in here about that. http://www.crankshaftcoalition.com/w...EI_distributor It talks about a holley but yours is the same. |
#16 | |
