Old 05-10-2016, 08:48 PM   #1
Squareforceone
Squareforceone's Avatar
What rear gear do I have calculation
I have an s10 that i'm trying to figure out my rear gear ratio without pulling the cover on. It's a 327 with a th350 at 60mph I'm running 2500 rpm my tires are 235/75R15's
Rust is better than rice.
Squareforceone is offline   Reply With Quote
Old 05-10-2016, 08:54 PM   #2
geezer#99
geezer#99's Avatar
Re: What rear gear do I have calculation
Punch your numbers into here.
http://www.advanced-ev.com/Calculators/TireSize/
Old 05-10-2016, 09:01 PM   #3
Squareforceone
What do I put for diameter ? Sorry for the dumb question
Old 05-10-2016, 09:09 PM   #4
geezer#99
geezer#99's Avatar
You guys really need to learn the metric system!! LOL!!
I'm still learning it after 40 years of it.
I'll give you the short answer, not the calculation.
Usually a 235 is 29 inches tall. Actually 28.87 inches by calculation.
Anytime you don't know a tire height, cross section etc just search for your size on tirerack. All the dimensions are there.
Old 05-10-2016, 10:09 PM   #5
jocko
jocko's Avatar
Calculates to a 3.55:1 rear, not exactly a common truck ratio - at least not for older trucks anyway. However, since you clearly don't have a stock setup and an S10 isn't "that" old, all bets are off - unless the 60 mph is from a GPS and not your dash (i.e. no way to know if the rear tire dia is stock to the rear gear/trans output shaft speedo gears, etc. If you do (or did) use a GPS, then it can be calculated more accurately. Below is for a TH400, but it shares the same 3rd gear final drive of 1:1, so it works for comparison. (I used 28.9" for the tire)
Old 05-10-2016, 11:56 PM   #6
Squareforceone
Thanks everyone I didn't know a whole lot about the truck i just bought it. It's an 84 s10 with with a 67 327 a th350 they 60mph was from the speedometer but has been checked against gps for accuracy
Old 05-11-2016, 10:29 AM   #7
Keith Seymore
Keith Seymore's Avatar
Based on this I'd guess 3.42 or 3.73.
Probably time for the "spin the driveshaft method" (or pull the cover).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-11-2016, 11:19 AM   #8
gmachinz
At 60 mph with a 26" tall tire I was hitting right at 3K and those were 3.73's and I had a TH400 at the time. This was in a Monte Carlo I had at time.
gmachinz is offline   Reply With Quote
