05-10-2016, 09:41 PM | #1 |
Change Instrument Cluster, now Speedometer stopped working.
05-10-2016, 09:48 PM | #2 |
The Older Generation
Re: Change Instrument Cluster, now Speedometer stopped working.
If nothing moves I would say that the cable is not inserted into the back of the speedometer correctly or the housing collar is not screwed all the way onto the back of the speedometer. The threads are pretty fine on the collar and it is easy to get it cross threaded. I would take it back apart and try it again. LockDoc
05-11-2016, 07:51 AM | #3 |
05-11-2016, 09:28 AM | #4 |
Thank you. I'll work on that. I wanted to make sure I wasn't missing something.
08-23-2016, 08:04 PM | #5 | |
08-23-2016, 08:21 PM | #6 |
I don't think any adhesive would work in the very high rotation regime those parts get up to. You may have to bite the bullet and pop $20 for a new speedo cable.
08-23-2016, 08:29 PM | #7 | |
The cable end should be crimped onto the cable. If you have an older auto repair shop near you they may have a crimper. LockDoc
08-24-2016, 12:37 AM | #8 |
11-05-2016, 07:22 PM | #9 | |
Thank you! |
11-05-2016, 09:02 PM | #10 | |
You should be able to just pull your inner cable out from the top and measure it. You put the new one back in the same way unless you are buying the complete assembly.... LockDoc
