Old 09-29-2003, 01:17 AM   #1
TIMSPEED
TIMSPEED's Avatar
Cab Mounts: Part #'s and how hard to replace?
Anyone replace the cab mounts on their C10 yet? I'm 99% sure mine are shot and that's what's causing my truck to ride like crap, as well as lean BADLY.
How hard are they to change? Should I HAVE them changed or can I do it myself?
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 09-29-2003, 02:05 AM   #2
BaggedC10
Under construction!
BaggedC10's Avatar
I installed new PST body mounts recently and it was very simple.
1. Remove the grille and headlight bezels to access the front radiator support bolts.
2. Loosen the driver side cab and radiator support bolts. Just enough to have 1" of up and down movement.
3. Completely remove all passenger side bolts.
4. Raise the cab by placing a floor jack under the cab floor support (The one that extends out to the rocker panel). The body should be raised just enough to remove the mounts.
5. Remove the mounts from the steel cups and install the new units.
From here, it's pretty obvious what has to be done.
I would also recommend installing new hardware. Dirt and etc. builds up inside the mounts and the hardware goes south. Check-out LMC for new hardware.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 09-29-2003, 03:06 AM   #3
TIMSPEED
TIMSPEED's Avatar
Got a part #?
See Them Here
Old 09-29-2003, 04:43 AM   #4
Nvbowtie
Nvbowtie's Avatar
I just did mine the other nite, my front end was already apart so the actual cab mounts only took about 30 minutes.
http://www.unlimited2u.com/sept
www.unlimited2u.com/chevy
1980 Chevy C-10 Silverado
1988 Chevy Blazer Tahoe
Nvbowtie is offline   Reply With Quote
Old 10-10-2003, 12:59 AM   #5
Orion 762
Cab mounts and welded bolts
I'm trying the 'cab mount replace" game as well, but on both of my "forward cab mounts", the long thru-bolts have been welded to the floor (on the inside of the cab).
I have the new mounts/bolt/nuts etc. Do I need to break these welds, OR do I just try to re-use the thru-bolts as-is?? It looks like a TIG weld where the original "hex head" of the bolt is melted/welded to the flooring. I guess this was done to keep them from backing off on their own.
Any hints?? If I keep the original welded-in bolts, it looks like I'll have to raise the cab (somehow) more than 4" to get clearance to install the new rubber mounts.
If I need to remove these thru-bolts, what's the best way to "break the old weld" without chewing a hole thru my floor?
Any help will be appreciated.
Orion 762
Orion 762 is offline   Reply With Quote
Old 10-10-2003, 04:45 AM   #6
Nvbowtie
Nvbowtie's Avatar
Unscrew all 4- bolts
Jack the cab at each mount location individually and replace the mounts.
Thread the bolt back in a few turns just so it wont fall out.
Just be careful and make sure the cab is secure and won't fall on your hand while you pull the old mount out.
tighten all the bolts to specified torque and re-check after a couple hundred miles.
that's it your done...
Old 10-10-2003, 05:08 AM   #7
TIMSPEED
TIMSPEED's Avatar
Hopefully, after replacing the cab mounts, my truck will ride like factory fresh!
See Them Here
Old 10-10-2003, 09:37 AM   #8
BaggedC10
Under construction!
BaggedC10's Avatar
Did you buy polygraphite or rubber?
Old 10-10-2003, 01:47 PM   #9
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Is there a part number for the steel cups? Im sure atleast one of mine has just rusted off and is gone.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
