Old 05-11-2016, 10:42 AM   #1
chastain90
chastain90's Avatar
Reassemble questions
I am putting my interior back together and started with the door glass. I got my vents and door glass in. Questions tho, Does the rubber weatherstrip on bottom of vent go in the door or outside of the door? It wrinkles up if I try to leave it on outside of the door but when its in the door there is a small gap, maybe 1/8 inch. Is the gap supposed to be there? Just worried for rain getting in the door.
Also, the bolt that goes in from inside the door just under the vent window. Does that tighten the gap between them? And what size bolt is this because I don't have it.
Lastly, Where can I order the rubber for the door glass channel? The one that is inside the door NOT the felt for the vent window.
Thanks for any help.
chastain90 is offline   Reply With Quote
Old 05-11-2016, 12:12 PM   #2
A1971Blazer
A1971Blazer's Avatar
Re: Reassemble questions
not sure about the vent window rubber but I just ordered the glass channel runs from Mane's truck parts......mine were broken to pieces and laying inside the bottom of the door..I should have the new ones soon.....I'll let you know how the quality is...
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 05-11-2016, 12:49 PM   #3
chastain90
chastain90's Avatar
Thanks, Do you know about that bolt or screw under the vent window?
Old 05-11-2016, 12:57 PM   #4
A1971Blazer
I'm not sure about it but I am about to gut some extra doors that I have to salvage parts from......gonna try to do it tonight.
if you don't get an answer before I get to them.....I will find out how they assemble....also will look at the vent window rubber for you.
what year is yours? I think that screw assembly on the 69-71 is slightly different from the '72
on edit:
it looks like the rubber goes to the inside of the door
here is the assembly of the screw with the ferrule....one side on mine is missing.....looking in the empty hole it looks like a reinforcing screw for the vent window assembly?
1967 C10 Step side
1968 C10 Step side
Old 05-11-2016, 01:44 PM   #5
hemi43
hemi43's Avatar
The rubber goes inside of the door. You may have to trim a bit off so that it doesn't get pinched between the door skin and the vent window channel.
The bolt is a #10 (3/16) sheet metal screw around 2" long, and it screws into a stamped clip. When tightened, it squeezes the door inner and outer against the 1/4 window glass channel. I used glass cleaner as a lubricant to put everything back together.
hemi43 is offline   Reply With Quote
Old 05-11-2016, 02:16 PM   #6
chastain90
chastain90's Avatar
Ok thanks alot! I guess I will need that screw to tighten my door to the rubber on the vent window. That's what I was thinking but helps to know for sure. Mine is a 72, I dont know if I had the ferrule like yours or not. I have 2 screws at the bottom of the door panel for the vent window then 3 screws on the top rail that go into the top of the vent.
Old 05-11-2016, 02:46 PM   #7
1rippen6
I should have the screw and ferrules will look tonight and let you know.
1rippen6 is offline   Reply With Quote
Old 05-12-2016, 12:02 AM   #8
Chad22873
Chad22873's Avatar
If you have extras Dwayne, I may be interested since it appears as if hemi is not going to reproduce the top notch ones that he made and gave us all a shot of in his build thread. I was really hoping he would offer some up for sale.
BR549
Chad22873 is offline   Reply With Quote
Old 05-12-2016, 07:35 AM   #9
1rippen6
I think I have a couple sets will have to look but mine are 72 only pieces not sure what Hemi has but the 71s are different should be able to look tonight no one should be showing up at the garage this evening.
Old 05-12-2016, 09:26 AM   #10
hemi43
hemi43's Avatar
HAHAHA !! The ones I made took a lot of time and there's no way I could sell them at a reasonable price. If I could sell a few thousand, I would make a mold and mass produce them. LOL
Old 05-12-2016, 10:36 AM   #11
chastain90
chastain90's Avatar
What are the differences between the 71 and 72 screws?
Old 05-12-2016, 09:44 PM   #12
1rippen6
Post 4 is 69-71, the picture I posted is 72 they need cleaned up but should be fine.
Old 05-13-2016, 07:31 AM   #13
A1971Blazer
I got the rear glass channel runs in from Mane's yesterday afternoon and installed them last night....they seem to be quality made pieces and fit well.
The bottom 2 screws on the passenger side door that hold the channel were broken off and I broke the top one off taking it out....I took it out and managed to get them drilled out and re-tapped......bead blasted, painted and re-installed it.
I haven't put the new division felt in yet, but the new rear runs really tightened up my windows and put and end to the squeaking and rattling. I'm gonna put new rubber in the wing windows as soon as it arrives....
1967 C10 Step side
1968 C10 Step side
Old 05-13-2016, 07:41 AM   #14
chastain90
chastain90's Avatar
Rippen, What do you want for a set of those screws? Prefer the ones with the clip in case I don't have mine
Old 05-13-2016, 12:07 PM   #15
1rippen6
24 shipped let me know if still interested
Old 05-13-2016, 12:27 PM   #16
chastain90
chastain90's Avatar
Seems kinda steep for 2 screws..Not saying they aren't worth that. Could you do any less?
Old 05-13-2016, 12:31 PM   #17
1rippen6
How's 19, does seem steep but you have to disassemble the door to get the clip out, buy an envelope to mail it, and then drive to the post office. It's just a small item but all that time adds up.
Old 05-13-2016, 12:42 PM   #18
chastain90
chastain90's Avatar
Ok, PM your info I don't think I have it still.
Old 05-13-2016, 12:44 PM   #19
1rippen6
PM sent
Old 05-13-2016, 12:46 PM   #20
chastain90
chastain90's Avatar
how is the clip? is it rusted bad and are threads still good? Sorry forgot to ask.
Old 05-13-2016, 12:53 PM   #21
1rippen6
They are fine just metal tabs I will send the best 2.
Old 05-13-2016, 12:57 PM   #22
chastain90
chastain90's Avatar
Ok thanks,
