Old 05-11-2016, 12:54 PM   #1
chewychevy67
Adding a Headliner in a non headliner truck ??
Ok need advice. I added the moulding to my 67 but I cut off the tabs and added a screw in each of the 4 corners for support. Is this not enough even if I glue the headliner up? Will is warp and disform from either heat or weight of the headliner? Anyone have experience with this. Dnot want ot to look bad 5 years down the road.. Thanks
chewychevy67 is offline   Reply With Quote
Old 05-11-2016, 01:01 PM   #2
jwilb88
jwilb88's Avatar
Re: Adding a Headliner in a non headliner truck ??
The existing headliner in my truck was installed just like yours. 4 screws and the headliner was glued. I' don't have any pictures of it but it looked fine. The PO had installed it three years prior to me getting the truck.
jwilb88 is offline   Reply With Quote
Old 05-11-2016, 03:35 PM   #3
88Stanger
88Stanger's Avatar
LMC truck sells a molded plastic headliner that I got. It has a place for a stereo or in my case 3 gauges along with it comes with 4 speakers there. It is screwed into place. Looks nice if you ask me.
88Stanger is offline   Reply With Quote
Old 05-11-2016, 06:52 PM   #4
Andy4639
Old member
Andy4639's Avatar
Talking Re: Adding a Headliner in a non headliner truck ??
Mine is a add on it's been in the truck for years. I added some screws to it but it looks fine.
As long as the board is good and stiff it shouldn't sag. Mine isn't glued either.
I need to swap that red out for the grey.
Thanks for reminding me! Ha I hardly look up when I'm in the truck.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 05-11-2016, 07:04 PM   #5
OregonNed
OregonNed's Avatar
That looks sharp!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 05-11-2016, 10:02 PM   #6
chewychevy67
That's good. I really dreaded the thought of making all those holes in the roof.
