Old 05-11-2016, 03:35 PM   #1
Handmedown
Handmedown's Avatar
clunking
I have an 06 silverado1500. Every time I hit the tiniest bump there is a clunking sound in the steering wheel. I took it to firestone and they said idler arm. I took it to les schwab and they found that the passenger side wire that gos to the electric shock was broken off. schwab said that it could either be the electric shock or the steering box. My question is would the shock make a clunking noise just because of the electrical wire being not connected?
Handmedown is offline   Reply With Quote
Old 05-11-2016, 08:10 PM   #2
clinebarger
Re: clunking
Could be the Intermediate Steering Shaft rattling/clunking.
To be sure......
Tie the Steering Wheel with the Seat Belt so it cant move & break the Clock Spring.
Under the Hood where the steering shaft exits the firewall, There will be a 15mm headed bolt, Remove it.
Separate the Intermediate & Lower Steering Shafts by pushing the Intermediate shaft toward the rear of the truck.
Work the shaft in & out a good 20 times, This will redistribute the Grease in the Intermediate Steering shaft.
Reassemble the shafts & test drive, If the noise is now gone....You found your issue, It WILL come back in 5-10,000 miles.
You have a few options....Redo it every time the noise comes back, Install a grease Zerk in the shaft so you can re-grease with a gun, Or buy a replacement shaft from Borgeson http://www.borgeson.com/xcart/produc...ctid=1451&cat=
Don't bother buying a GM one.
clinebarger is offline   Reply With Quote
Old 05-11-2016, 10:17 PM   #3
Handmedown
Handmedown's Avatar
Re: clunking
Thanks for the reply! I went to the dealership today. They had no clue what it could be, until an old guy mechanic was walking by and said almost exactly what you just said. I'm going to give it a try this weekend.
Old 05-13-2016, 10:44 PM   #4
kaycee
kaycee's Avatar
Re: clunking
Yep do what clinebarger said ,that's what I did and no more clunk
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 05-25-2016, 01:55 AM   #5
71Custom10
71Custom10's Avatar
Re: clunking
I 2nd Clingbanger's solution. Been there, done that, actually need to do it now, again.
'67 Chevy Longbed Fleetside - Daily Driver(For Now)
'72 Cheyene Longbed Fleetside-Daily Driver
Best Towing Service
71Custom10 is offline   Reply With Quote
Old 05-25-2016, 02:25 PM   #6
Handmedown
Handmedown's Avatar
Re: clunking
The dealership replaced the steering shaft, since I had no time. Steering is completely quiet now, thanks Guys
Old 05-26-2016, 09:59 AM   #7
LBJ
Re: clunking
This happened to me and my (then) new 2004 Silverado. Took it in once and the problem came back a short while later. Second time to the dealer, they fixed it for good. Not sure what they did, but that was 12 years and 80K miles ago.
LBJ is offline   Reply With Quote
Old 05-26-2016, 11:51 AM   #8
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: clunking
Same deal for '06 K2500HD? I have had a rattle in the front for some time now. I thought it was the disc brake calipers, but now I'm thinking it might be the steering shaft.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 05-26-2016, 03:56 PM   #9
truckdude239
truckdude239's Avatar
Re: clunking
where is the best place to nistall a grease fitting to lube the shaft every some offten
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 06-15-2016, 09:40 AM   #10
solidaxel
solidaxel's Avatar
Re: clunking
Does anyone have a pic of a Zerk installed in the shaft?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 06-15-2016, 10:49 AM   #11
Willie Makeit
Willie Makeit's Avatar
Re: clunking
I've owned 4 of these year trucks over the past 10 years. ALL of them did it at some point. I've always done the "remove the 15 bolt and stroke it" fix on all of them about once a year. Matter of fact, just did this exact thing to my Silverado SS daily driver on Sunday night.
It is a KNOWN issue with GM trucks, but GM has pretty much instructed dealerships to "play dumb" when it comes to it. It is not a safety issue, so they don't want to spend the money to issue a recall.
Willie Makeit is offline   Reply With Quote
Old 06-15-2016, 11:52 AM   #12
solidaxel
solidaxel's Avatar
Re: clunking
I removed the "center" 1 . 5mm bolt but nothing moves.
Is it the upper or lower shaft that is supposed to move, the one with the boot that goes to the R&P?
LS 3 4L70E
Old 06-15-2016, 07:39 PM   #13
clinebarger
Re: clunking
The one that goes into the cab.
Old 06-16-2016, 08:35 AM   #14
solidaxel
solidaxel's Avatar
Re: clunking
Well I will work a bit harder on it this time !
LS 3 4L70E
Old 06-16-2016, 08:18 PM   #15
Willie Makeit
Re: clunking
DO NOT allow it to spin! Just stroke it back and forth about 25-30 times full stroke.
Old 06-17-2016, 10:44 AM   #16
solidaxel
solidaxel's Avatar
Re: clunking
So just in case I will put a index mark on the two shafts!
LS 3 4L70E
Old 07-01-2016, 12:07 AM   #17
chase@ridetech
chase@ridetech's Avatar
Re: clunking
I just bought an 06 and have the same issue...looks like I have a new plan for the weekend.
Chase Mundy
Direct Line: (812) 481-4736
Email: chase@ridetech.com
chase@ridetech is offline   Reply With Quote
