05-11-2016, 05:17 PM | #1 |
water pump
I'm sure this has been asked and answered many times, but here goes: I have a 400 small block with a long pump (photo) in my '56. I just put a new alternator belt on, and I noticed a very small amount of "play" or movement--just a tad--in the water pump pulley. It's not leaking, and it runs 180 degrees in the Florida weather, but I thought there should be no free play at all. Bearings going? Anything different about a pump for the 400 SB? Thanks!
Not sure why the photo is upside down. It's fine on my computer! Last edited by chevyhed53; 05-11-2016 at 05:23 PM. Reason: fixing photo |
05-11-2016, 06:34 PM | #2 |
Re: water pump
Any long pump should be fine. But just get one for a 400 SB when you are ordering. Pick a vehicle that would have come with one (76 3/4 ton truck should work).
05-11-2016, 06:52 PM | #3 |
Re: water pump
Will do. Thanks!
05-11-2016, 11:37 PM | #4 |
Re: water pump
If you have photoshop all you need to do is import the photo to Photoshop than do a save as and rename it and direct it back to the same folder and it will remain right side up.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
