05-11-2016, 08:42 PM | #1 |
Coolant overflow
So when my truck gets up to temp and driven for a while the radiator will have lost a decent amount of coolant once cooled. Obviously I need an overflow... is anyone using the factory radiator and cap with an overflow that seems to be functioning? I don't want to replace the radiator right now it's only 3 years old thanks in advance guys
70 C10 working on a LSx swap 4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol |
05-11-2016, 10:17 PM | #2 |
Post Whore
Re: Coolant overflow
Are you loosing water out overflow tube or into engine? Probably not your radiator..have you changed the cap?
05-11-2016, 10:41 PM | #3 |
You don't necessarily need an over flow bottle. The full mark on a radiator without an overflow is several inches down from the cap, so if you fill it all the way to the top, it will puke out what it cant hold, after that it should be fine if it isn't overheating.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
05-12-2016, 11:33 AM | #4 |
............... X 2 !
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
05-12-2016, 09:40 PM | #5 |
I have changed the cap. Are there higher pressure caps available?
05-13-2016, 12:21 AM | #6 |
Post Whore
I have a 25lb cap on mine..
05-13-2016, 12:49 AM | #7 |
meowMEOWmeowMEOW
I've always run a 16lb I believe.
05-13-2016, 08:35 AM | #8 |
I use a 7# cap and 50 50 anti freeze with a catch can
I run a electric fan and A/C Are you sure you do not have any air trapped in your system
05-13-2016, 02:06 PM | #9 |
Engine has about 15-20 hours on it so I would think that the air bubbles would be gone. Where do you get a higher pressure cap
05-13-2016, 03:12 PM | #10 |
Old member
Just for the sake of doing our part for the environment put a over flow on it. They are cheap enough and it will save you money in the long run. Just take the hose that it runs out of now and hook it to the over flow.
05-13-2016, 04:02 PM | #11 |
Post Whore
The air pockets solidaxle is talking about is in the engine..did you fill the engine through the top radiator hose until full? This will eliminate most of the air that's trapped..if you've ran it that long without it overheating I don't think you've got that problem..if its got air trapped it will immediately run hot and the thermostat doesn't open. Radiator caps are sold by parts stores everyday..from my research when doing my swap I found they recommend less than 20lb for older style engines and over 20lb for newer ls engines..doesn't mean a lower than 20lb won't work its got more to do with how much pressure your system can stand without problems and they also said get the biggest one you can find..my old 350 already had the 25lb on it so I just left it on. Like andy suggested get you a overflow tank..that way any coolant that goes out the overflow due to high pressure will be pulled back in when it cools off and the pressure drops...in theory..
