My defroster covers interior with moisture
Does anyone have an idea why this is happening? I don't smell antifreeze, can't find any leaks, and my windshield doesn't leak. Carpets are bone dry. Can't find any moisture in the cab. But when it rains, and I turn the heater/defrost on it covers the entire interior with moisture. Dash, windows, gauges. It is blowing hot and there is strong air coming from the defrost vents. If I don't turn on the heater at all it is not as bad. I also notice that when I wash the truck, I get small circles of moisture just above the defrost vents. I'm stumped. This truck was stored in a heated garage it's whole life, 17k original miles. It's like a time capsule. The rubber is all very soft, it was like buying a one or two year old truck. everything works like butter. Windows, cold air vents, door latches. This is the only thing that seems out of sorts.
"A man's got to know his limitations" 1969 Chevy C20 Camper Special 1968 Chevy C-10 short/fleet 1970 GMC Jimmy 4x4 (SOLD) |
Re: My defroster covers interior with moisture
Your heater core is shot. It leaks coolant into the heater box creating steamy air being blown. You are better off using your wing vents and a towel until you replace it
![]() Join Date: Mar 2000
Yup what K says.
Saskatoon, Saskatchewan Canada |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
I don't think it's the heater core for four reasons.
1. He doesn't smell anti-freeze- I've had three vehicles with leaking heater cores and the smell is unmistakable. 2 He hasn't said anything about low coolant. 3. The carpets are not soaked. Mine were every time. 4. It only seems to happen after a wash or heavy rain. This sounds like a leak into the heater box maybe a drain hole is plugged, If he has AC there should be a drain for condensation in the lowest part of the system with a rubber drain tube to the outside, or the heater core box gasket isn't sealing.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Bought the truck in Portland, OR three weeks ago. Drove it home to Brentwood, CA. (East edge of the S.F. Bay Area) So I've only had it for three weeks and put 1000 miles on it. Coolant seems to be staying put so far. It doesn't have AC. Plan to pour some water in the cowl vents today and check if it's draining properly.
Thanks for all the input so far.
Just an idea, but you might check the rubber grommet where the antenna coaxial cable goes through the cowl. I had a dried and cracked grommet that allowed water to seep down the cable and drip into the GM under-dash air conditioner unit. It also happened right after I washed the truck or when it was raining. I had condensation out the vents when the AC was turned on.
POP
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
I had exactly that happen in my 1975 Pontiac Bonneville. I was driving home from college in 2001 and the defroster blew moisture onto the windshield.
I had to get a new heater core. I guess water could be getting into the system though from outside, like the guy said he had happen with his antenna grommet. Anyone else want to weigh in? I do know that to remove your heater core you'll have to have your hood off along with the passenger side hood hinge. Fortunately the heater box is easy to take apart and replace the core, I did that to mine. |
![]() Join Date: Jan 2002
Im agreeing that its the heater core. I had simolar symptoms and it was a bad heater core.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
If it only happens after rain/outside water. Happens ,Not seein it being a heater core? Try riding around with heat/defrost on dry day for giggles?
Born Psycho
![]() Join Date: Feb 2001
i've seen this truck in person and it is beautiful inside and out. my first thought was heater core too but it only happens when water is on the outside and like Larry stated-the coolant level isn't going down and the unmistakable coolant smell is not present. there has to be a small leak somewhere from the outside getting in. now, Larry, where are the pics so the rest of the board members can drool over this jewel.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
I responded without reading the info much at all. I thought I saw you could smell anti-freeze and stopped reading there, when I was already thinking heater core. I've seen them leak without getting the cab wet, though.
I'd guess it's a seal to your heater or that antenna seal
Is the coolant water, or a mix?
If it only happens when it rains maybe a leak between the body and the heater system? |
#13 |
Sorry Jerry. I can't figure out how to edit my signature. How am I supposed to post pictures?
#14 |
So I poured water in the cowl vent on both sides. It drains beautifully. It is a beautiful 80 deg today and sunny. I ran the defrost on high and it fogged all the windows but not to near the degree it did on the rainy day. All the windows fogged then the windshield started to defog above the defrost vents. Absent was the heavy moisture on the rest of the interior surfaces. The seal between the heater box/fan and firewall is soft and pliable and appears in really good shape. The weather strip between the cowl and hood is cracked and misshapen. I ordered a new one today. I'm busy working the rest of the night but tomorrow I will try pouring water across the front of the cowl while running the defroster on high. See if that replicates the symptoms. If not, I guess I can remove the cowl vent for the fist time in it's life ): I'll keep updating the progress. And maybe get Jerry to come over and show me how to post pictures. ._.
#15 |
#16 |
Son, of, a,..........hey, I got it (:
#17 |
Take that Jerry!
#18 |
And the coup de grace........
#19 |
Believe it or don't
#20 |
Holy mackerel, that thing is beautiful. Congrats for sure. Enjoy!
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED ![]() |
#21 |
Born Psycho
#22 |
Looks like the garage couldn't keep the cab mounts from rotting a bit, regardless of mileage... but that's an easy fix!
See, now that you've posted photos, your defroster issue is forgotten, and we're all just going to look at your truck. ![]()
#23 |
![]() Join Date: May 2010
I was watching that one on eBay and drooling! Same color as my 69, but mine doesn't have the white top. I'm glad to see a forum member got it.
#24 |
I know, I should be working. But...
The story I got from the broker who bought the truck from the widow of the original owner is this: Oscar, the original owner, ordered the truck in December of 1968 from Appleway Chevrolet in Spokane, Washington. He took delivery, around the same time he ordered a slide in camper in January 1969. He wrapped the camper in foam before installing it which explains the condition of the original paint in the bed. He parked it in a heated garage, with the doors ajar so the weather strip would not get crushed, and only took it out to go camping. (I'm sure camping was a hoot with this guy. He probably spent the whole trip waxing his baby.) He died Feb. 6, 2014 at age 92. The broker also had the camper and it looked just as pristine. My buddy, Eric, and I flew to Portland to buy the truck then drove it home over two days. We stopped in Redding, Ca. long enough to enter it in one of the many small car shows during Kool April Nights. I was able to retain the original title issued 1/15/69. I also have the build sheet with seat spring imprint, protect-o-plate, owner's manual, and the pre-delivery service and adjustment check sheet. It also came with an instruction card on how to document an accident. Not sure if the dealer gave these out or it was an insurance company. There is no indication of either. The placards you see on the trans hump look to have been made by a trophy shop or something similar. They are plastic with a faux wood grain and are engraved to read "G.W. 10,000". On the back side there is a decal that reads "8,000 GR". Not sure what that's about. I remember as a kid seeing some of the grey beards driving these rigs with similar decals on the side. Anyone know what that was for? The GVW is listed on the VIN plate as "7500". BTW, these placards were attached to the fenders with screws just above the "Custom Camper/20" emblems. The holes are still there but the paint was not damaged. For your edification, the blue can that is plumbed to the PCV line is a Marvel Mystery Inverse Oiler. Had to look it up. Allows an adjustable amount of Marvel's top end lube to get sucked into the intake and burned. Supposedly to lubricate the valves. Oscar also added a high energy ignition, spots, bumper guards, driving lights, SW gauges for vacuum, trans oil temp, and oil pressure, a trailer brake, air horn, gun rack, and CB radio (removed before sale to my dismay). I can see some leftover hardware, holes, and brackets for side steps and mud flaps. There's a few scrapes on the top of the bed sides where the camper made contact and a couple of buggered spots on the rear window trim from same. Also stone chips on the front of the hood that have been touched up and some in the windshield as well. But overall it looks like it's no more than a couple of years old. I found Oscar's obituary online. He worked for Hyster as a field rep and service manager and sounds like he was an upstanding, hard working dude. If you're listening Oscar, I'll take good care of her. She'll be pampered but used. Once I figure out a way to protect the paint in the bed, she'll be hauling materials for projects, car parts, and two old dogs who will be loving life with the wind in their hair, er, fur. TTFN.
#25 |
Nice rig !!! so cool you know all the history of her!
