Old 05-12-2016, 11:53 AM   #1
idahoflywaters
Burnt up Battery
I acquired this amazing 68 last year and trying to get it started(and stopping) again. I'm a never ever resotoration. I might have burnt up the battery? I put new battery cables in and the ground from the frame that heads to the alternator smoked up and the positive cable to the battery was super hot, hot enough to melt plastic around the terminal. Was this a connection issue or do i need to re-wire the truck?
idahoflywaters is offline   Reply With Quote
Old 05-12-2016, 12:26 PM   #2
old Chevy guy
old Chevy guy's Avatar
Re: Burnt up Battery
Sounds like it may be a connection issue. Make sure your big cable from the negative battery terminal to the engine block is good. Sounds like all the starting voltage tried to go through that small ground on the alternator.
old Chevy guy is offline   Reply With Quote
Old 05-12-2016, 12:34 PM   #3
michael bustamante
michael bustamante's Avatar
the ground should go to the engine block or the alternator mount bracket i believe then the block should have a ground strap to the frame and one to the cab.
1967custom
michael bustamante is offline   Reply With Quote
Old 05-12-2016, 12:43 PM   #4
idahoflywaters
Awesome thank you, I will make sure the connection to the block is cleaned.
Old 05-12-2016, 02:01 PM   #5
Bigdav160
Bigdav160's Avatar
Lets see more pics of the truck. It looks great from the front. The coral pink is uncommon
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 05-12-2016, 06:00 PM   #6
old Chevy guy
I actually have a 67 I picked up for parts in the yard that color. Didn't think it was a GM color. more pictures would be cool.
