Old 05-12-2016, 02:43 PM   #1
made2drag
made2drag's Avatar
Post your c10 with 2 coils cut up front
ive done it on a 78 k5 and got like 4.5 inches and ride was ok. I didn't get a chance to shim the uppers to correct the camber before selling it. Got another c10 and now im thinking about chopping 2 and riding it like that til I get all my bag stuff bought.
post up your rides guys. I know its been done on the site
made2drag is offline   Reply With Quote
Old 05-12-2016, 02:54 PM   #2
dragn91
dragn91's Avatar
Re: Post your c10 with 2 coils cut up front
Here's 2 coils cut on my c20 I just ordered drop spindles I had them before but swapped to 6 lug. I wouldn't go over 11/2 coils tho c10 drop spindles are pretty cheap and are much better ride I'm putting mine on air soon so it didn't bother me. Keep in mind this is a c20 and has a 305 40 22 tire a c10 will probally look a lot lower with 2 cut
http://
dragn91 is offline   Reply With Quote
Old 05-12-2016, 03:01 PM   #3
made2drag
made2drag's Avatar
cool dragn91! that thing looks tough!
Old 05-12-2016, 03:14 PM   #4
KQQL IT
At the body shop.
KQQL IT's Avatar
2 cut
4 inch bolts for alignment
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 05-12-2016, 03:55 PM   #5
made2drag
made2drag's Avatar
perfect!!!!
Old 05-12-2016, 04:30 PM   #6
KQQL IT
At the body shop.
KQQL IT's Avatar
Originally Posted by made2drag View Post
perfect!!!!
Thanks, I've done several like that. Even know the shim stack to get it close too.
I use 1/2" hardened washers 9 in the rear 11 in the front and cut all the bump stop stuff off.
And a simple flip out back.
No notch either.
Is it the correct way, I don't know but it's how I do it.
Old 05-12-2016, 05:18 PM   #7
made2drag
made2drag's Avatar
cool...you seem to have it down to a science...thanks. looks like the camber is good too.
Old 05-12-2016, 05:20 PM   #8
grancuda
grancuda's Avatar
I understand 1 coil is approx 2" drop, so would 2 coils be 4"?
grancuda is offline   Reply With Quote
Old 05-12-2016, 05:35 PM   #9
made2drag
made2drag's Avatar
I think I got 4 1/2
Old 05-12-2016, 05:38 PM   #10
made2drag
made2drag's Avatar
with 2 coils cut the spring is very loose when you jack truck up. and you have to make sure they stay in place where they should be as you let jack down slowly. but it wasn't often I had to jack it up so high my tires were off the ground.
Old 05-12-2016, 05:39 PM   #11
made2drag
made2drag's Avatar
best thing to do is 1 coil cut and 2.5 or 3 inch spindles. Im going to do just bags and brackets and not do spindles so I was just going to do a free drop for a couple months.
Old 05-12-2016, 06:02 PM   #12
KQQL IT
At the body shop.
KQQL IT's Avatar
Nah, short shock and relocate the shock eye with 4wd shock bracket.
Just before the coil comes free shock runs out of travel.
Old 05-12-2016, 06:52 PM   #13
dragn91
dragn91's Avatar
What's the part number for the short shock? And does the 4x4 shock bracket just bolt on?
Old 05-12-2016, 07:06 PM   #14
KQQL IT
At the body shop.
KQQL IT's Avatar
No clue can't recall that, it's the 2nd upper shock bracket with factory dual shocks, and yes 2 holes with 3/8 bolts.
Old 05-13-2016, 07:22 AM   #15
Keith Seymore
Keith Seymore's Avatar
Cut two coils in front, relocated spring hanger brackets in rear.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-13-2016, 08:42 AM   #16
terrylgreenjr
I'd like to know more about the shock relocation. do all the frames have the holes? Do you have a part number or the model that it comes off of?
terrylgreenjr is offline   Reply With Quote
Old 05-13-2016, 09:46 AM   #17
KQQL IT
At the body shop.
KQQL IT's Avatar
You have to drill 2 holes, as they're riveted by gm.
I happened on them on junkyard crawl.
http://67-72chevytrucks.com/vboard/s...d.php?t=503971
Old 05-13-2016, 09:57 AM   #18
Keith Seymore
RPO Z75 - Dual Shock option.
Available on 1/2 and 3/4 ton 4wd.
Very good idea, btw.
K
1979-1986
1986 - 2019
Old 05-13-2016, 10:24 AM   #19
KQQL IT
At the body shop.
KQQL IT's Avatar
http://www.wholesalegmpartsonline.co.../14072700.html
It's part 24 on the schematic
Old 05-13-2016, 12:12 PM   #20
Keith Seymore
Sidebar: RPO Z75 is now the nameplate conversion RPO for Cadillac (ie, if you order an Escalade it would be a K10906 & Z75). Further evidence that they reuse RPO codes.
K
1979-1986
1986 - 2019
Old 05-13-2016, 12:27 PM   #21
N2TRUX
Happy to be here
N2TRUX's Avatar
You have to drill 2 holes, as they're riveted by gm. I happened on them on junkyard crawl. http://67-72chevytrucks.com/vboard/s...d.php?t=503971
Originally Posted by Keith Seymore View Post
RPO Z75 - Dual Shock option. Available on 1/2 and 3/4 ton 4wd. Very good idea, btw.
K
Ironically I just made a post on the subject in my latest build thread 85 GMC Sierra "Scarlett" I have a set of RideTech brackets that were part of the upgraded kit on my 77 build. I priced it as well as several other aftermarkets kits and they were all around 100.00 or higher. I thought about fabbing my own. After I then considered time and materials, that wasnt economical either. Some research lead me to another option. Pictured below are Ford F250 brackets (Yeah, I know) that can be easily purchased for 13.00 each. They will need to be cut down and fresh holes drilled, but the price makes it something worth checking out.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
"Refining Sierra"
Old 05-20-2016, 02:16 PM   #22
made2drag
made2drag's Avatar
nice info guys...I really appreciate it
Old 05-20-2016, 08:01 PM   #23
RodsGreen10
RodsGreen10's Avatar
Porter Built makes a really nice shock relocate kit.
RodsGreen10 is offline   Reply With Quote
