Old 05-12-2016, 09:02 PM   #1
Mrturner1
Mini spool install help
So I got all the parts in but now I can't spend it inside the carrier to line up a pin that goes all the way through. Is it supposed to be this tight without any shims? The two blocks that go in the middle are pretty tight it's gonna be kind of tough to separate them to get the axles in with the c clips
Mrturner1 is offline   Reply With Quote
Old 05-12-2016, 09:03 PM   #2
Mrturner1
Re: Mini spool install help
Pic
Old 05-12-2016, 11:22 PM   #3
Robznob11
Robznob11's Avatar
It's been a good while since I put mine in but I remember it being very tight and a pain to get in. Also makes a lot of worry some noise when Turing tight in the shop😕
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 05-12-2016, 11:33 PM   #4
Mrturner1
Ok good, as long as I know it's supposed to be this tight then I feel better.
Old 05-13-2016, 12:38 AM   #5
Mrturner1
I just watched a YouTube video and the guy left the tires on, pulled all the spider gears, put the two side peices of the mini spool in, pushed the axles in, put c clips on, pushed the two rectangle blocks in the middle nice and easy by hand?! Mine had to be tapped in with a hammer. Then he spun the tire until the pin hole in the spool lined up with the hole in the carrier, slid the pin through no problem and done. Why is mine so tight that the blocks have to be tapped in and I can't spin it with the tires it's so tight?
