What size Spindle.
I'm in the process of ordering some 2 1/2 drop spindles. Here are the specs of my rotors. Do I order spindles for the 1 inch thick rotor or not? Thanks a ahead
Re: What size Spindle.
Pic
Well those rotors are the 1" variety so if that's what you're using then you should be good. I'd definitely just measure the ones on the vehicle to be sure
Diggin The SquareLife
ALWAYS measure tour rotors! Its easy to take your wheel off to see
The hub snout on the 1" rotors fit behind the center caps of aftermarket wheels much easier. I usually swap everything out to 1" rotors if Im buying spindles. If thats something you're interested in in the future, it may save you a headache later...
"I'm Dirk Diggler enough to own and operate a vehicle of this caliber" -veinbar Dropped and LS Swapped SWB 87 Build Thread |
Damn I think I ordered 1.25
![]() ![]() I would hate for them not to fit
1982 step side |
they would fit.....but your calipers, brake hoses, bearings wouldn't fit....
