Old 05-13-2016, 10:41 AM   #1
Isaiah92260
Isaiah92260's Avatar
Will Corvair Radio for my 63'?
Good morning Fellas, I just bought pretty decent 1963' Corvair Radio with its faceplate for my 63' truck, my dash is a little hacked up so this will look great since the Corvair faceplate will cover up the cut up face opening and radio knob holes. Anyways, my question is how does the radios mount up? It has a back mounting L-Bracket that in sure I can cut down to length if it is too long, in assuming that using two nuts won't be the past way to mount using the face plate.
Thanks guys
Isaiah92260 is offline   Reply With Quote
Old 05-13-2016, 10:42 AM   #2
Isaiah92260
Re: Will Corvair Radio for my 63'?
Front
Old 05-13-2016, 11:50 AM   #3
65chevysub
65chevysub's Avatar
I used to have a 63 Corvair radio in my 65 Chevy II and it fit. I think the old radio housings are the same size and of course the shafts are moveable. I mounted mine in the back with metal pipe strap. Lots of holes for mounting to the radio and dash.
Good luck
65chevysub is offline   Reply With Quote
Old 05-13-2016, 12:36 PM   #4
padresag
Good luck
If you go to the hardware store it is called plumber's hanger strap
ron
padresag is offline   Reply With Quote
Old 05-13-2016, 01:38 PM   #5
65chevysub
65chevysub's Avatar
Thanks Padreseg
I was draeing a blank on the correct name of it.
Old 05-13-2016, 02:42 PM   #6
Isaiah92260
ron
Thanks I'll take a look after work
Old 05-13-2016, 02:43 PM   #7
Isaiah92260
Good luck
Awesome thanks buddy !
Old 05-13-2016, 09:25 PM   #8
Chknlyps2
ron
Out here in California the stuff that comes in a roll I have always known as plumbers tape.
Chknlyps2 is offline   Reply With Quote
Old 05-13-2016, 09:56 PM   #9
Isaiah92260
I'm from Los Angels and always know plumbers tape as the white tape to deal faucets and pipers... Thank you btw, I've seen this stuff before! I'm gonna pick it up tomorrow in the morning from ACE hardware
Old 05-13-2016, 10:05 PM   #10
Chknlyps2
I am only about 35 minutes up the hill from you, if I was going down there tonight or in the morning I have a couple partial rolls and would bring you some... but tomorrow I am heading the other direction to check out what looks like a real nice 64 C20.
Old 05-13-2016, 10:18 PM   #11
padresag
sure that you are not thinking of the teflon tape for threads, the stuff with holes was actually used for hanging pipe. lot of it used to be copper but I haven't seen copper for years. perhaps it got to expensive
just checked the copper is 70.00 for 25' while steel is 15.00 - 20.00 for a 100'
https://www.grainger.com/category/pi...ecatalog/N-qv6
ron
Old 05-13-2016, 11:07 PM   #12
Chknlyps2
ron
I thought it was funny to call it tape when I first heard it 35 or so years ago. I don't remember teflon tape back then, just pipe dope. I have been in one form of construction or another all my life and around here that is what they call it. Probably because it is on a roll.
Old 05-14-2016, 09:16 AM   #13
Isaiah92260
No worries bud! I am in Palm Springs right now!
Old 05-14-2016, 09:18 AM   #14
Isaiah92260
ron
Wow copper? What difference does it make for it to be made in copper?
Old 05-15-2016, 01:29 AM   #15
Isaiah92260
Just got the radio on, It looks great!
Old 05-15-2016, 01:30 AM   #16
Isaiah92260
Mounted
Old 05-15-2016, 11:57 AM   #17
Mackie
Mackie's Avatar
Dissimilar metals = galvanic reaction = corrosion
`63 C-10 Shortwide
Roller 305 LT1 cam, Eddy 500
T5
Mackie is offline   Reply With Quote
Old 05-15-2016, 12:55 PM   #18
61K10
61K10's Avatar
radio looks good. much better.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 05-15-2016, 02:11 PM   #19
Isaiah92260
Thanks. I had to modify the opening cuz the radio was a 1/4" bigger but it was fine since my dash was already cut so I didn't mind, the radio faceplate covers everything and makes it look so much better.
Old 05-15-2016, 02:38 PM   #20
jtrichard
You DO NOT want to use steel/galvanized plumbers tape to hang/strap copper pipe MOST copper plumbers tape is COPPER PLATED steel a lot cheaper than all copper
I have had many discussions at home depot/hardware stores when I ask wheres the PLUMBERS TAPE and they take me to the THREAD SEALING tape/ TEFLON (trade mark) tape....... HAD to splain many many times what THEY are selling
jtrichard is offline   Reply With Quote
Old 05-15-2016, 03:52 PM   #21
Isaiah92260
