LS Camaro Tank Fuel Pump Question
I hope this is the correct forum for this question. I am putting a 5.7 vortec engine in my 70 c10 and I'm going to use a gas tank from a 2001 camaro that I already have on hand. The only problem is that the fuel pump module has been dissected by the PO. The plastic module is there but the electric fuel pump and everything else attached to it is gone. Is it possible to put a new electric pump on the assembly? I wanted to avoid buying a new assembly since they are so overpriced. I tried researching but I couldn't find any information on how to replace just the electric pump only. Any help would be appreciated. Thanks.
Re: LS Camaro Tank Fuel Pump Question
Yes a new pump can be installed. I put the equivalent of a whalbro (or however it's spelled) 255lph in the factory plastic pump housing. Idk bout short beds but long bed took me relocating the rear most frame bracket where the taillight bracket attaches (if I remember correctly) there is a guy on here that did a big write up on how he mounted it. Mine has worked out fairly well.
70 C10 working on a LSx swap ![]() 4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol |
Thanks, mine is a long bed. Do you happen to know the part number of the pump you bought? And also maybe point me in the direction of some instructions on how it goes together? Like I said everything is missing so I don't know how it goes together.
Old member
Quick google search.
2001 Camaro fuel pump. $81.95 Vehicle Fit •1999-2002 Chevy Camaro Fuel Pump & Sending Unit Module for V8 5.7L Models •1999-2002 Pontiac Firebird Fuel Pump & Sending Unit Module for V8 5.7L Models ![]() http://www.1aauto.com/1999-02-chevy-...FUokhgodGbgMLw
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
