Steering shaft suggestion
what is the best way to go from
1"dd (steering column ) to 3/4" 30 spline (steering box) ? |
![]() Join Date: Sep 2015
Re: Steering shaft suggestion
"Orange Crush" |
Factory steering shafts cut and welded?
![]() Join Date: Jul 2007
I'm not a fan of the cut and weld idea as too many guys screw that up by doing it wrong.
The U joint setup that VS posted is a popular option but you can probably do it with stock pieces if you hunt a bit and use the DD pieces to adjust your length. A couple of photos of what you are working with and what you need to do would go a long way towards getting a simple fix that didn't break the back and was totally safe.
I kinda got the idea as to what to use, i cant make up my mind as to start from the 1"dd.
the shaft size is what i cant decide 1"dd shaft or 3/4"dd shaft. i know it is not that hard, but i dont want to overkill but not go smaller etc, you know what i mean. ![]() |
#6 | |
If you use some Chinese one it could bind and snap while turning.... No thank you ![]()
"Orange Crush" |
Try mid '90's Jeep Cherokee from your local u-pull-it
![]() Join Date: May 2007
too short, I have one on the shelf.
I use borgeson u-joints and slip shaft BRG-014931 Steering Universal Joint, Steel, 3/4 in. DD, 3/4 in. 30-Spline BRG-015252 Steering Universal Joint, Steel, 1 in. DD, 1 in. DD BRG-450036 Steering Shaft, Steel Alloy, Universal the slip shaft is 3/4 on the lower side and 1" on the upper. no need to cut to length, its got a slip joint. there are better places to be cheap than brakes or steering, in my cruddy opinion.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
#9 | |
"Orange Crush" |
no. no and again no
use the u-joint adapter ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
Here is what I did for $10 (Astro Van shaft at junk yard). I had the 74 shaft from donor truck. U joints are not as elegant as Borgsen, but plenty strong. Retains slip joint for frame and cab movement (critical in my 4wd off road application) or collapse in collision. No welding except for spot welds after installing set screws treaded into the inner shaft.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
#12 | |
![]() had to fork out $25 for my astro van column ![]()
#13 |
Got it in a bundle with a bunch of other parts, $50/5 = $10.
