1972 Jimmy - Brake Light Continuity bad 1 side
Howdy All,
I have a Brake light problem I was wondering if anyone could shed some light on. The right hand brake light is out, running lights work fine on both sides. I checked the socket, bulbs are all good. What might cause the brake continuity to go out on one side only ? Anyone had a similar issue ? Cheers, James. ![]() |
Re: 1972 Jimmy - Brake Light Continuity bad 1 side
Could be several things, bad wire somewhere, or bad turn signal switch come to mind. Do both turn signals work?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
![]() Join Date: Jan 2007
If you can swap bulbs per side and they work on only one side...I would say bad ground or wire somewhere.
Thanks ls1nova71 - Ill have to run the right hand side back from the socket. I have had an intermittent problem with the turn signals so I'm guessing related.
Thanks lks dcvn,
I have indeed put he left bulb on the right and same result. No continuity on the RHS. Will continue to check out the ground situation. |
I believe the power for the brake lights goes through the column (since they are turn signals as well). If your issue isn't at the back, I would be looking at the turn signal switch.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205 1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears 1996 Chevy Suburban K1500 350/4L60E |
