Old 03-29-2002, 10:24 AM   #1
lukecp
Formerly yellow72custom
lukecp's Avatar
Post Gaskets
What is the best selant to make gaskets stay sealed longer? I have heard several different methods, from using no selant at all, to covering both sides of the gaskets in selant, or just putting a bead on one side. Usually, i give both sides of the gakets a light coat of Permatex blue RTV selant. It has worked pretty good in the past, but i did it on some valve cover gaskets and they leaked even worse about 2 months later. What kind of selant should i use? Red, black, or blue?
Lucas
"Another proud owner of one of the coolest trucks ever built"
drop_shift@hotmail.com
My Daily-Driver: '72 Chevy LWB Custom/10. Rebuilt 350, 300 HP thanks to a few go-fast goodies. Ochre with a white top. Future plans include a frame off restoration, and maybe a blown 383.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 03-29-2002, 10:56 AM   #2
Pont
I need another Barley Pop
Pont's Avatar
Post
Well, if were talking about head or intake gaskets, I would say no sealer. Use Felpro only. For something like valve covers, timing cover, oil pan, etc. I use a product called Gaskacinch (sp). Apply it like you would 3M weatherstrip adhesive. Lightly apply to gasket and surface, let it tach dry for about 15 minutes, then put it together. Hasn't failed me yet after all the engines I've built.
67 SWB 4x4 - 396 BB / SM420 4 spd
8" lift / 15x14 Welds & 35X14.5 SSR's
Grants Pass, OR
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 03-29-2002, 11:00 AM   #3
lukecp
lukecp's Avatar
Post
I am talking about stuff like valve cover, fuel pump, oil pan, ect...
Old 03-29-2002, 11:03 AM   #4
Pont
Pont's Avatar
Post
Gaskacinch will work perfect. Most parts stores I've been to carry it. It's also used as a belt dressing.
Grants Pass, OR
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
Old 03-29-2002, 11:13 AM   #5
Shane
Shane's Avatar
Post
I have had my best luck with valve covers by using RTV on the valve cover, then place gasket on the valve cover and place clothes pins around the perimeter of the valve cover/gasket area to hold the gasket flat while the RTV is drying. Once the RTV is dry, remove the clothes pins and install the valve cover on the motor without any sealant on the gasket-to-head surface. This has always produced leak free covers and it also lets you remove the valve covers at a later time without destroying the gaskets.
The most important thing here is using a good quality gasket. (I prefer the neoprene/rubber type gaskets as opposed to the "cork" type.) And make sure you don't over tighten the valve cover bolts. If I remember correctly they only require about 7 lbs/ft. of torque. Its also a good idea to make sure the valve cover base itself isn't warped. It is real easy to warp the base by over tighteneing the covers and then you have a surface that looks like a wash board.....not real easy to seal...LOL! I have seen a bunch of covers where the person thought if they give the bolt another half turn, the leak would stop....but actually made it worse.
Hope this helps.
Keep On Truckin'
Shane
slecroix@bellsouth.net
Athens, Alabama
[This message has been edited by Shane (edited March 29, 2002).]
Shane is offline   Reply With Quote
Old 03-29-2002, 11:54 AM   #6
69 longhorn
Post
I use the same method Shane has posted,rtv on the cover to gasket,& dry on the head. Felpro has a thick set of cover gaskets(neoprene impregnated cork),that seem to work the best. Some of the thin gaskets will leak ,as there is not enough thickness to take up any distortion in the covers.Good luck......69 longhorn.
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 03-29-2002, 11:18 PM   #7
704x4
Thumbs up
i'm telling you guys once you use
"the right stuff" comes in easy cheese container
you will never use silicone again
expensive but worth every cent
70 3/4 ton 4x4
FOR SALE
Greene, IA
704x4 is offline   Reply With Quote
