Another windshield washer question.
Hi again everybody!
Since I am going to switch to a more modern pump, is there a hose fitting made into a "Y" shape that will allow a single hose from the new pump to supply both squirters? I've found several such connectors online, but can anyone show me what they used? Last edited by In The Ten Ring; 05-14-2016 at 01:39 PM. |
Re: Another windshield washer question.
go into local autoparts store and look or at best ask for sum help
#3 | |
Old member
![]() Quote:
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
The auto parts stores....I just never imagined they carried such things. I'll have a look next time out. Thanks.
If you are planning on buying a new pump at a store, they often come with fittings. My pump new from NAPA was $20 Canadian and came with everything I needed.
Posted via Mobile Device |
