Squarebody tractor - real or shopped ?
This was posted on another forum.
I can't tell if it's real or photoshopped. If it's real, all I can say is "WHY???".
"Off the grid and on the seven day weekend plan" "One person cannot know everything, but between all of us, there isn't much we don't know." |
Re: Squarebody tractor - real or shopped ?
I cant tell if real or not but pretty cool.
Cruzzzn' Vet
Looks real to me, Bad A$$ puller!
Having played around with Photoshop quite a bit, I can tell you it is VERY difficult to photoshop something like that because of the detail in the grass. You can't just "slap" the rear end of a tractor in behind the individual blades of grass, photoshop doesn't work like that. You need solid, clearly defined borders, or at a minimum a sharp contrast between foreground and background. Blades of tall grass are going to have neither.
I say it's genuine.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!! |
Thanks, .........
I figured you kids would enjoy seeing the pic. After all, it IS a squarebody ..........
even has the muffler. i say its real.
and its badass |
That's cool. I'd plow a field with it!!
1995 GMC 4x4 1/2 ton 1999 Jeep Wrangler w/ 33's 68 camaro 350/350 1987 Chevy 3/4 ton 4x4 Suzuki DRZ 400s Dual Sport 1971 chevy long bed 2x4 194? Dodge 2.5 ton 1980 Chevy Cheyenne 4x4 1/2 ton I6/sm455 1989 Chevy V30 crewcab dually 454/TH400 |
![]() Join Date: May 2015
I think that's just a fencepost there trailertrash...I thought the same thing when I first saw it..
![]() Join Date: Apr 2016
I would say its real,,, they removed the original side fuel tank or tanks on the truck to fit the tractor rear axle assembly and relocated the fuel tank between the fenders,,, so seen in pic. Great pic find for conversation.
most likely tractor trans/rear under it. one my uncles did something similar but with a ford with gas tank behind seat. they used it do play in mud/pull stuff.
STILL PLAYS WITH TRUX
Don't know!
But what I want to know is why did they remove the drivers door? |
#13 |
Cruzzzn' Vet
Robbed Peter for Paul or something like that
#14 |
![]() Join Date: Jul 2014
I am calling it 'shopped'... I zoomed in and clearly, there was grass over the lower part of the steering wheel.
But the dead giveaway, is the Vent Window Frame and the Mask used to 'protect' certain areas when editing... I could use the tilt column though... that appears real
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...d.php?t=655783 --Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...ghlight=Belair "Life is tough - wear a cup!" "Old Enough to Know Better - Too Young to Resist" "Junk is something you will need three weeks after you throw it away." |
#15 |
noticed the cab and rear axle are not at same angel.
cab is angled front away allowing you to slightly see the back of the cab where as the rear axle is angled towards you in the front allowing you to see more of the fender in the back ground. im going with photoshopped but something i would like to build and drive lol
1981 Silverado C10 LS/4l60e My truck may be loud and ugly but I love her like bacon |
#16 |
The tractor tires are mounted backwards
#17 |
That's because all the forward gears are stripped... When reverse finally went out, he just left it where it died.
| Bookmarks |
