quadrajet and bracket
Got my quad rebuilt and hooked up using the Edelbrock Universal bracket
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: quadrajet and bracket
Do you like how it is working?
I haven't started it yet but assuming you mean the bracket, I was just thrilled to find something I didn't have to completely make from scratch that seemed to work.
Do you see a problem? If so please help me before I mess it up even more. I'm an assembler by trade not a mechanic! This seemed like a such a straight forward and easy scenario until I went to bolt it all together. None of my factory brackets I had seem to put the cables in the right spot. The universal bracket from $ummit wasn't even close. I just google searched until I found something that was within reach and ordered this piece. It's heavy enough material, was affordable, but the holes they suggest put the cables too far away from the carb. I went for it because someone said in the remarks they made it work by drilling and moving the brackets up. Thanks skipper |
#4 | |
A little further away!! What are you doing for a pcv system? |
Isn't the bracket suppose to bolt on a the carb rear bolt? hard to see.
just googled it and it does bolt to the intake. can you move it forward on the intake?
1961 chevy K10 my build is------------61K10 build |
Old style center fill intake with breather cap
