![]() Join Date: Oct 2006
250 header install question
I picked up some Langdon headers of Craigslist.
Im hoping to install them soon and get rid of my old long tube headers. My question is to those who have installed the Langdons before. Is there anything that I should look for when I go to install them? Can This be done by myself,or will I need an extra set of hands? Thanks in advance
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
Re: 250 header install question
Mornin' Sal!!!
A couple tips for ya'!! The locating dowels on each end of the head should be pulled out and the holes tapped for a threaded stud. Better sealing that way and easier to install. The washers used on the other studs need to be matched to each joint between the header flange and the intake flange. You might need to do a little grinding on them so they sit flat and make equal contact on both flanges. |
outstanding!! thanks
What Geezer said is 100% correct. I also uses Studs at every location. Makes the alignment so much easier. Take your time with the grinding and torqueing. When you are happy with the contact area tighten slowly. After it is running re-torque a couple of more times. Makes for a long term seal.
Thanks to you both.
