Old 05-15-2016, 10:21 AM   #1
tobascofred
1970 C10 step side rear coil replacement
Trying to remove old HD springs - bottom coil holder is a bolt that goes completely through the trailing arm - no issue.
The top coil holder bolt wants to spin on me. The frame rail top has the bed wood directly on top of it, so I am assuming that the nut is actually inside of the frame rail, as well I'd assume it should have been welded in place? Anyone ever had this issue and a solution?
tobascofred is offline   Reply With Quote
Old 05-15-2016, 11:06 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 1970 C10 step side rear coil replacement
Cut the head off the bolt with a grinder and cutoff wheel.
Keith
Convert to disc brakes.
Old 05-15-2016, 04:03 PM   #3
tobascofred
Duh... when I reached around the inside of the frame rail I felt a wall so I assumed it was a complete boxed frame rail. But no, it is not - there is some bracing that boxes the frame right where the coils mount, but a wrench can be snuck in from the front or back to hold the nut.
